please help me about ultrasonic sensor
Hello everybody.I am student of class seven of Rajshahi Unversity School,Bangladesh.I am very new in Arduino world.
I am facing a problem with ultrasonic sensor HC-SR04 .Here is my code…
int trigger=7;
int echo=6;
long time=0;
long dist=0;
Serial.begin (9600);
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
digitalWrite(trigger, LOW);
delay(5);
digitalWrite(trigger, HIGH);
delay(10);
time = pulseIn(echo, HIGH);
dist = (time/2) / 29.1;
if (dist >= 10000 || dist <= 0)
Serial.println("No measurement");
Serial.print(dist);
Serial.println("cm");
in serial monitor ,always give me distance between 3300cm-3400cm.but the real distance is 200cm.please help me .I need your help…
Here is a code example that works:
const int triggerPin = 7;
const int echoPin = 8;
long duration;
int cm, mm;
  pinMode(triggerPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(5);
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(10);
  // Read the signal from the sensor : a HIGH pulse whose
  // duration is the time (in microseconds) from the sending of
  // the ping to the reception of its echo off an object
  duration = pulseIn(echoPin, HIGH);
  // Convert the time into a distance
  cm = (duration / 2.0) / 29.1;
  mm = (duration / 2.0) / 2.91;
  Serial.println(cm);
  Serial.println(mm);
The timings in the pulse are a factor of 1000 too high. The function delay() is a millisecond delay. The functioning examples use a microsecond delay.
thanks a lot, I was suffering from this problem .Your suggestion help me to detect my problem.thanks again......
