Please help me for logical conditions.
I try to program a Car security system using an RFID and IR Sensor and the output is a servo motor
this is my codes
if((digitalRead(IR) == HIGH) && (digitalRead(RFID) == HIGH))
myServo.write(90);
else if(digitalRead(IR) == LOW)
myServo.write(0);
it's works fine
but my IR sensor is a LOW logic output and when I change the codes like this
if((digitalRead(IR) == LOW) && (digitalRead(RFID) == HIGH))
myServo.write(90);
else if(digitalRead(IR) == HIGH)
myServo.write(0);
my servo is not functioning well.
Can someone teach the right logical condition for this
thanks in advance.
it's works fine
Why change it?
Pete
lordpopo09:
it's works fine
   myServo.write(90);
   myServo.write(0);
The first thing is to find out what is causing the problem
Change the code a little so you can print the values of the variables and then you can see what is happening
  irVal = digitalRead(IR);
  rfidVal = digitalRead(RFID);
  Serial.print("IR ");
  Serial.print(irVal);
  Serial.print("   RFID ");
  Serial.println(rfidVal);
  if(irVal == LOW) && (rfidVal == HIGH))
    myServo.write(90);
  else if(irVal == HIGH)
    myServo.write(0);
It may also be wise to split your IF clause into two to make the logic more obvious
if(irVal == LOW)
     if (rfidVal == HIGH) {
        myServo.write(90);
    myServo.write(0);
...R
Getting data from an IR sensor generally requires more than knowing if the pin is HIGH or LOW at some arbitrary point in time.
What kind of RFID reader outputs a HIGH or LOW on a digital pin?
