please help me :/ i have problem at first else if
#include <math.h>
int backLight = 13;
#include <math.h>
int analogPin0 = 0; // potentiometer wiper (middle terminal) connected to analog pin 2
int analogPin1 = 1; // potentiometer wiper (middle terminal) connected to analog pin 3
int analogPin2 = 2; // potentiometer wiper (middle terminal) connected to analog pin 4
int hba = 2;
int hbb = 6;
int hb0 = 9;
int hb1 = 10;
int hb2 = 11;
int hb3 = 12;
float val;
int val0;
int val1;
int val2;
pinMode(backLight, OUTPUT);
digitalWrite(hba, LOW);
digitalWrite(hbb, LOW);
digitalWrite(hb0, LOW);
digitalWrite(hb1, HIGH);
digitalWrite(hb2, LOW);
digitalWrite(hb3, HIGH);
delay(100);
else if (val1<=250 && val>=32)
digitalWrite(hba, HIGH);
digitalWrite(hbb, HIGH);
delay(100);
else if (val1>250 && val<32)
if (val0<val2)
digitalWrite(hb1, LOW);
else if (val2<val0)
digitalWrite(hb3, LOW);
else if (val1>250 && val>=32)
if (val0<val2)
else if (val2<val0)
An else statement needs to follow in if statement. Yours does not.
All code must be in a function. Yours is not.
Once you have got the code to compile will it work anyway ?
The digital pins default to being inputs if not set as outputs using pinMode(), so what will the digitalWrite() commands in your code do ?
Incidentally, I was amused by the variable names and the comments in these lines
It may be deliberate, but you should note that your liberal use of delays of half a second will make the code seem very unresponsive to changes of potentiometer values.
oh thank you
