please help me im going crazy.
i have this project im doing it contacting 4 thing together, which they are the easyVR shield, locker, keypad and whistle, i tried to program them separately and they work just fine but when i try to join them together i get this errors problems now i have the locker, keypad and whistle working together fine but i can’t get the easyVR to work with them because it’s keep interrupting the hole program and if i do nothing would work. i tried to add a whisker so if i press it the easyVR would work and if it’s not the keypad will. here is my code please help am lost.
#include <Password.h>
#include <Keypad.h>
#include <Servo.h>
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
  SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_ARDUINO = 0,
enum Group1
  G1_OPEN = 0,
  G1_CLOSE = 1,
EasyVRBridge bridge;
int8_t group, idx;
Servo myservo1;
Servo myservo2;
int whisker1=0;
int val=0;
int LCD = 1;
int Wrong_Password=0; //counts how many times the password entred wrong
Password password = Password( "2A2B" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; //  columns
// Define the Keymap
char keys[ROWS][COLS] = {
    '1','2','3','A'  }
    '4','5','6','B'  }
    '7','8','9','C'  }
    '*','0','#','D'  }
byte rowPins[ROWS] = {
  26,28,30,32 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte colPins[COLS] = {
  34,36,38,40 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  pinMode (4,INPUT);
  pinMode(13,OUTPUT);
  pinMode (LCD,OUTPUT);
  char keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  myservo1.attach(42);
  myservo2.attach(44);
  Serial.write(17);
  Serial.write(12);
  Serial.write(132);
  Serial.println("Who am i ;)");
  Serial.write(168);
  Serial.println("or use the passcode");
// bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(0);
  group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
void loop(){
  whisker1=digitalRead(4);
  if(whisker1==HIGH)
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_ARDUINO:
        // write your action code here
        // group = GROUP_X; <-- or jump to another group X for composite commands
    case GROUP_1:
      switch (idx)
      case G1_OPEN:
      case G1_CLOSE:
 if(whisker2==LOW){
  keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
  case PRESSED:
    Serial.print("Pressed: ");
    Serial.println(eKey);
    switch (eKey){
    case '*':
      checkPassword();
    case '#':
      password.reset();
    default:
      password.append(eKey);
void checkPassword(){
  if (password.evaluate()){
    Serial.println("Success");
    Serial.write("Success");
    digitalWrite (42,HIGH);
    myservo1.writeMicroseconds(1300);
    myservo2.writeMicroseconds(1700);
    delay (1000);
    myservo1.writeMicroseconds(1500);
    myservo2.writeMicroseconds(1500);
    delay (10000);
    myservo1.writeMicroseconds(1700);
    myservo2.writeMicroseconds(1300);
    delay (1000);
    //Add code to run if it works
    Wrong_Password=0;// reset the counter
    password.reset(); // to reset the password
  else{
    Wrong_Password=Wrong_Password+1;
    Serial.println("Wrong");
    Serial.write("Wrong..");
  //  Serial.println("#S|MAILMAN|[]#");
   if (Wrong_Password >=3){ // if the password has been entered 3 times or more wrong start the alarm
   for(int repeat=0; repeat<=10;repeat++){
    for (int i=900; i > 20; i--){
      digitalWrite(13,HIGH);
      delayMicroseconds(i);
      digitalWrite(13,LOW);
    for (int i=200; i > 20; i--){
    delay (100);
    for (int i=20; i < 700; i++){
    for (int i=20; i < 100; i++){
  }//end of if(Wrong_Password....
and here is the errors
sketch_may07a.ino: In function ‘void setup()’:
sketch_may07a:78: error: expected initializer before ‘.’ token
sketch_may07a.ino: At global scope:
sketch_may07a:200: error: expected unqualified-id before ‘if’
thanks
Is this line meant to be like this?
Apart from that, without line numbers it's hard to know what the error messages mean.
The first message usually means there is a typo somewhere before the error that is identified.
...R
Is this the line before the first error?
What is the purpose of that 'char' there?
-br
if(whisker2==LOW){
  keypad.getKey();
That looks like it is outside of any function.
Difficult to tell with the indentation
awol , im trying to make the keypad active if the whisker is low billroy , if i didn't write char it would give me this problem.
sketch_may07a:78: error: 'keypadEvent' was not declared in this scope
Robin2 , it gives the command to the LCD to write on it "who im i" so the owner or reader would know what to say which is the trigger of the easyVR.
Yes, but is that code part of a function?
will i changed it to 1 because there is only 1 whisker and if it become low it should activate the keypad.
I don't understand that. Can you sort out the indentation using the auto-format tool (ctrl-T) in the IDE, then repost your code.
#include <Keypad.h>
#include <Servo.h>
#endif
#include "EasyVR.h"
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_ARDUINO = 0,
enum Group1
  G1_OPEN = 0,
  G1_CLOSE = 1,
int8_t group, idx;
Servo myservo1;
Servo myservo2;
int whisker1=0;
int val=0;
int LCD = 1;
    '1','2','3','A'    }
    '4','5','6','B'    }
    '7','8','9','C'    }
    '*','0','#','D'    }
void setup(){
  pinMode (4,INPUT);
  pinMode(13,OUTPUT);
  Serial.write(17);
  Serial.write(12);
  Serial.write(132);
  Serial.write(168);
  // bridge mode?
  if (bridge.check())
    cli();
  // run normally
  port.begin(9600);
    for (;;);
void action();
void loop(){
  if(whisker1==HIGH)
    do
    if (idx >= 0)
      return;
    if (idx >= 0)
      uint8_t train = 0;
      char name[32];
      Serial.print(idx);
      action();
      if (err >= 0)
void action()
  switch (group)
  case GROUP_0:
    switch (idx)
    case G0_ARDUINO:
  case GROUP_1:
    switch (idx)
    case G1_OPEN:
    case G1_CLOSE:
else if(whisker1==LOW){
      keypad.getKey();
      case PRESSED:
        switch (eKey){
        case '*':
          checkPassword();
        case '#':
          password.reset();
        default:
        delay (1000);
        delay (10000);
        delay (1000);
      else{
            delay (100);
and here is the errors now after
sketch_may07a:78: error: ‘keypadEvent’ was not declared in this scope
sketch_may07a:200: error: expected unqualified-id before ‘else’
keypadEvent is embedded in another function, which is why the compiler can't see it.
Edit: as is checkPassword
Sort out your braces.
