// Pin definitions
#define HIN_A 8
#define LIN_A 9
#define HIN_B 10
#define LIN_B 11
#define HIN_C 12
#define LIN_C 13
// State variables
bool stateA = false;
bool stateB = false;
bool stateC = false;
uint8_t phase = 0; // 0-119 (divided into 120 steps)
// Timer configuration
void setupTimer1() {
noInterrupts();
// 10kHz PWM (16MHz / (1(prescaler) * (1599+1))) = 10kHz
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 1599; // Set compare value (10kHz)
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS10); // Prescaler 1
TIMSK1 |= (1 << OCIE1A); // Enable timer compare interrupt
interrupts();
// Set pin mode
pinMode(HIN_A, OUTPUT);
pinMode(LIN_A, OUTPUT);
pinMode(HIN_B, OUTPUT);
pinMode(LIN_B, OUTPUT);
pinMode(HIN_C, OUTPUT);
pinMode(LIN_C, OUTPUT);
// Initialize all outputs to LOW
digitalWrite(HIN_A, LOW);
digitalWrite(LIN_A, LOW);
digitalWrite(HIN_B, LOW);
digitalWrite(LIN_B, LOW);
digitalWrite(HIN_C, LOW);
digitalWrite(LIN_C, LOW);
// Configure timer
setupTimer1();
ISR(TIMER1_COMPA_vect) {
phase = (phase + 1) % 120; // 120 steps (each step = 3 degrees)
// Phase A (0° reference)
handlePhase(HIN_A, LIN_A, phase, &stateA);
// Phase B (120° delay)
handlePhase(HIN_B, LIN_B, (phase + 40) % 120, &stateB);
// Phase C (240° delay)
handlePhase(HIN_C, LIN_C, (phase + 80) % 120, &stateC);
void handlePhase(uint8_t hin, uint8_t lin, uint8_t currentPhase, bool *state) {
if (currentPhase < 60) { // First half cycle (0–59) - HIN ON
if (!*state) {
// Apply dead time (4 µs)
digitalWrite(lin, LOW);
delayMicroseconds(4);
digitalWrite(hin, HIGH);
*state = true;
} else { // Second half cycle (60–119) - LIN ON
if (*state) {
digitalWrite(hin, LOW);
digitalWrite(lin, HIGH);
*state = false;
// Main operation handled in timer interrupt
I am trying to generate 3 PWM signals for a three-phase inverter. Each PWM consists of one HIN and one LIN, so a total of 6 output pins (3 HINs and 3 LINs) are used. Phase 1 PWM, Phase 2 PWM (120 degrees out of phase from phase 1), and Phase 3 PWM (240 degrees out of phase from phase 2).
The frequency of all waveforms must be 10kHz, meaning each cycle must be 100 µs, and a dead time of approximately 4 µs is required between HIN and LIN. When executing the code below, the PWM phase difference was correctly implemented, but the PWM period came out to be 12 ms. Please tell me how to fix this.
And if the overall concept itself to make 3ph PWM is wrong, let me know what kind of code I should use to generate the PWM signals I want. I'm completely new to Arduino. I'd be grateful if you guys help me out. thx
