please help me node mcu - esp8266- rebooting
hi guys
please help me
i try to control 12 relay with esp8266 via browser
i write my code and it test it
when i control just one pin esp work no problem
when i try to control 2 pins or more just rebooting and i donot know why
i google alot
about watchdog rest problem but i donot know how i can fix it
i sure too that my power so good (( 5v 2A ))
i hope guys help me how i can fix it
note i use linux os
i try to update firmware with esptool and nodemcu-pyflasher-master
i installed java python pyserial and tools i need it
but every time i try to execute the esptool or nodemcu-pyflasher-master no thing run or happen
really i hope you guys help how i can fix all that problems
i use arduino IDE !
my code
#include <ESP8266WiFi.h>
const char* ssid = "my wifi name";
const char* password = "my wifi password";
int led0 = 0;          //1
//int led1 = 1; tx0
int led2 = 2;          //2
//int led 3 = 3; rx0
int led4 = 4;          //3
int led5 = 5;          //4
int led6 = 6;          //5
int led7 = 7;          //6
int led8 = 8;          //7
int led9 = 9;          //8
int led10 = 10;        //9
int led11 = 11;        //10
int led12 = 12;        //11
//int led13 = 13; rxd2
int led14 = 14;        //12
//int led15 = 15; txd2
//int led16 = 16; wake
int value = LOW;
WiFiServer server(80);
void setup(){
delay(100);
///////0
pinMode(led0, OUTPUT);
digitalWrite(led0, LOW);
/////1
//pinMode(led1, OUTPUT);
//digitalWrite(led1, LOW);
/////2
pinMode(led2, OUTPUT);
digitalWrite(led2, LOW);
/////3
//pinMode(led3, OUTPUT);
//digitalWrite(led3, LOW);
/////4
pinMode(led4, OUTPUT);
digitalWrite(led4, LOW);
/////5
pinMode(led5, OUTPUT);
digitalWrite(led5, LOW);
/////6
pinMode(led6, OUTPUT);
digitalWrite(led6, LOW);
/////7
pinMode(led7, OUTPUT);
digitalWrite(led7, LOW);
/////8
pinMode(led8, OUTPUT);
digitalWrite(led8, LOW);
/////9
pinMode(led9, OUTPUT);
digitalWrite(led9, HIGH);
/////10
pinMode(led10, OUTPUT);
digitalWrite(led10, LOW);
/////11
pinMode(led11, OUTPUT);
digitalWrite(led11, LOW);
/////12
pinMode(led12, OUTPUT);
digitalWrite(led12, LOW);
/////13
//pinMode(led13, OUTPUT);
//digitalWrite(led13, LOW);
/////14
pinMode(led14, OUTPUT);
digitalWrite(led14, LOW);
/////15
//pinMode(led15, OUTPUT);
//digitalWrite(led15, LOW);
/////16
//pinMode(led16, OUTPUT);
//digitalWrite(led16, LOW);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
server.begin();
Serial.println("Server started");
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
WiFiClient client = server.available();
if (!client) {
return;
Serial.println("new client");
client.println("Content-Type: text/html");
client.println("");
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head>");
client.println("<title>ATS Systems</title>");
client.println("<meta charset=\"utf-8\">");
client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"stylesheet\" href=\"http://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css\">");
client.println("<script src=\"https://ajax.googleapis.com/ajax/libs/jquery/1.12.0/jquery.min.js\"></script>");
client.println("<script src=\"http://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/js/bootstrap.min.js\"></script>");
client.println("</head>");
///led2
client.println("<body>");
client.println("<div class=\"container\">");
client.print("<h1>Elsayed Smart Home Device</h1>");
client.print("<h1>Room TV</h1>");
client.print("<p class=\"text-danger\">on-off Button:</p>");
client.print("<a href=\"/LED2=ON\" class=\"btn btn-success\" role=\"button\">ON</a>");
client.print("<a href=\"/LED2=OFF\" class=\"btn btn-danger\" role=\"button\">OFF</a>");
client.print("
client.println("Led2 pin is now: ");
if(value == HIGH) {
client.print("On");
client.print("Off");
///// led6
client.print("<h1>Room Light</h1>");
client.print("<a href=\"/LED6=ON\" class=\"btn btn-success\" role=\"button\">ON</a>");
client.print("<a href=\"/LED6=OFF\" class=\"btn btn-danger\" role=\"button\">OFF</a>");
client.print("
client.println("Led6 pin is now: ");
if(value == HIGH) {
client.print("On");
client.println("</div>");
client.println("</body>");
client.println("</html>");
while(!client.available()){
delay(1);
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
//////2
if (request.indexOf('/LED2=ON') != -1) {
digitalWrite(led2, HIGH);
value = HIGH;
if (request.indexOf('/LED2=OFF') != -1) {
value = LOW;
///////6
if (request.indexOf('/LED6=ON') != -1) {
digitalWrite(led6, HIGH);
value = HIGH;
if (request.indexOf('/LED6=OFF') != -1) {
value = LOW;
delay(1);
Serial.println("Client disonnected");
Serial.println("");
the serial debug report
s$l⸮⸮<⸮l⸮| ⸮l⸮ #|⸮⸮⸮⸮s⸮b⸮ c⸮⸮‘o⸮$g’⸮⸮⸮cp⸮⸮dsdsdp⸮’⸮ ⸮l⸮⸮ co⸮<l⸮⸮Ǐc⸮⸮go⸮d⸮⸮$⸮egn dags⸮ۓn Ì$`;⸮⸮g ⸮⸮l ⸮⸮g⸮
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
Most likely a hardware problem as in that you have insufficient current for the relays.
Only you know what you have.
i remove all relays but still the same problem !!
just rebooting
i build firmware with nodemcu site and i upload it via ( windows OS )
and still the same problem (( befor and after )) update the firmware !! just reboot
i note some thing that if i just control one pin just one work fine why !!
code of one pin
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
const char* ssid = ".......";
const char* password = "...................";
int led = 12;
int value = LOW;
void setup(){
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
Serial.print(".");
Serial.println("");
server.begin();
if (!client) {
return;
client.println("");
client.println("<title>First Project</title>");
client.print("<h1>ESP8266 Web Server</h1>");
client.print("<a href=\"/LED=ON\" class=\"btn btn-success\" role=\"button\">ON</a>");
client.print("<a href=\"/LED=OFF\" class=\"btn btn-danger\" role=\"button\">OFF</a>");
client.print("
client.println("Led pin is now: ");
if(value == HIGH) {
client.print("On");
delay(100);
client.flush();
if (request.indexOf('/LED=ON') != -1) {
digitalWrite(led, HIGH);
value = HIGH;
if (request.indexOf('/LED=OFF') != -1) {
value = LOW;
delay(100);
Serial.println("");
what happen here T_T
