Hi all,
I am working on a system which allows me to control LED and mp3 by triggering infrared sensors. There are 6 infrared sensors, they control 6 LEDs and 6 mp3 correspondingly, for example, sensor 1 is triggered, LED 1 lights and mp3 1 sounds, sensor 2 is triggered, LED 2 lights and mp3 2 sounds...and so on.
I have a similar code with only one sensor, one LED and one Motor. But I’ve no idea about how to make it works as 6 combinations. Please help me modify it or give some suggestions. Thanks a lot.
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 8; // the number of the pushbutton pin
const int ledPin = 11; // the number of the LED pin
const int MotorPin = 9; // the number of the Motor pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// counter to avoid the sleep mode
long counter=0;
long timingForSleepMode=11500;
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
pinMode(13, OUTPUT);
pinMode(MotorPin, OUTPUT);
digitalWrite(MotorPin, LOW);
digitalWrite(13,HIGH);
delay(3000);
digitalWrite(13,LOW);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == LOW) {
// turn LED on:
// play
digitalWrite(ledPin, HIGH);
digitalWrite(13, HIGH);
delay(50);
digitalWrite(ledPin, LOW);
digitalWrite(13, LOW);
//wait 5 seconds
//delay(5000);
digitalWrite(MotorPin, HIGH);
delay(5000);
delay(10);
// turn pause
delay(50);
delay(50);
// counter time
counter=millis();
timingForSleepMode;
// cut off motor
else {
// turn LED off:
//avoid sleep mode mp3
if ((counter+timingForSleepMode)==millis()){
delay(50);
counter=millis();
