I am trying to build an obstacle detecting robocar with the help of arduino uno. The other components used are an H-bridge with L298-N motor driver, a servo motor and HC SR-04(UV sensor). On powering the system, The car keeps on rotating in a circle and am failing to detect the fault in the code. This is the code
#include <Servo.h>
int motorpin1=7;
int motorpin2=6;
int motorpin3=4;
int motorpin4=5;
int servopin=11;
int trigpin=12;
int echopin=3;
int ena=9;
int enb=10;
long duration;
int distance=0;
int leftdist=0;
int rightdist=0;
int object=10;
Servo myservo;
myservo.attach(11);
pinMode(motorpin1,OUTPUT);
pinMode(motorpin2,OUTPUT);
pinMode(motorpin3,OUTPUT);
pinMode(motorpin4,OUTPUT);
pinMode(trigpin,OUTPUT);
pinMode(echopin,OUTPUT);
pinMode(ena,OUTPUT);
pinMode(enb,OUTPUT);
myservo.write(115);
delay(700);
analogWrite(ena,255);
analogWrite(enb,255);
delay(50);
distance=readping();
if(distance<=20)
movestop();
delay(300);
backward();
delay(400);
movestop();
delay(300);
rightdist=lookright();
delay(300);
leftdist=lookleft();
delay(300);
if(distance>leftdist)
turnright();
movestop();
turnleft();
movestop();
forward();
void forward()
digitalWrite(motorpin1,HIGH);
digitalWrite(motorpin2,LOW);
digitalWrite(motorpin3,HIGH);
digitalWrite(motorpin4,LOW);
void movestop()
digitalWrite(motorpin1,LOW);
digitalWrite(motorpin3,LOW);
void backward()
digitalWrite(motorpin4,HIGH);
void turnright()
digitalWrite(motorpin2,HIGH);
void turnleft()
int lookright()
myservo.write(50);
int distance=readping();
delay(100);
myservo.write(115);
return distance;
delay(100);
int lookleft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readping()
digitalWrite(trigpin,LOW);
delayMicroseconds(2);
digitalWrite(trigpin,HIGH);
delayMicroseconds(10);
duration=pulseIn(echopin,HIGH);
distance=duration*.034/2;
return distance;
Please help me in detecting any sort of fault so that i can proceed with my project.
Any kind of help would be appreciated
Thank You!!
