Please help me to identify a random LCD / Digitizer - compatible with arduino?
Hello,
I have here a LCD with and digitizer lying around, and was wondering if it is possible to use it with an arduino. Or to read out the digitizer values.
The LCD has a part number on the cable, it is: 20000938 00 A google search give some result, it seems to be a common type of a 7" LCD Display. The pins have no numbers or description.
The digitizer´s part number is: C098164C1-PG It has the following pins.
WAKE 1 VDD 2 RES 3 GND 4 INT 5 GND 6 SCL 7 SDA 8 GND
I can upload some pictures if it helps.
Thank you
Any ideas?
Bump this one more time.
