I am working on project with an Arduino mini, is kind of artistic, the goal is to make an animatronic commercial ad that looks like a giant printer, that prints the publicity, is for store that sells only printers
It may sound complex but its not, actually is very simple, it is just the Arduino mini, an stepper and a DC motor, I've tested everything by powering the Arduino with 4 AA batteries and two universal AC-DC adapters for each motor
like this one: http://media.wholesale-electrical-electronics.com/product/imgage/Electrical&Electronics/2010100918/44140b862d0384b42cf5f6df19fbffac.jpg
It works as expected
Now I want to make a power supply to feed everything from one single source, but I am having a very weird problem
I've made this:
First of all, the parts
LP-570 ac-ac converter 110 to 12-0-12, 0.5a, like this: https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcQFo2xBwSKUipcYR-Ic_B3yxNx9qIywyujTsWYkWlyqkqdV4_bOpA
2w04 rectifier bridge
L7805
L7809
I've connected the lp-570 to the rectifier bridge and then to the L7805 and L7809, am posting a picture of it so you can see what I did
The L7805 should supply 5 volts, but when I measured with a multimeter It shows me 2.5 volts, why???
The L7809 supplies 6,5 volts, again why!?? it should give 9 volts
I've tested by connecting the Arduino to the L7809 and see how it works, but when I do this it goes insane, is hard to explain, the Arduino behaves in a weird way, like going on and off repeatedly, but it is not a permanent damage, because when I connect the Arduino back to 4 AA batteries works fine
What am I doing wrong??????
