Hi everyone! I am a beginner at Arduino and am currently using an Arduino UNO. My goal for this project is to create a device (using a PIR) that could accurately blink an LED light whenever someone is close by. But in the PIR's sense, whenever any heat signature is nearby. My code is at the bottom, can anyone help me?
// This is an introduction to all the variables
int ledPin = 11; // LED
int pirPin = 2; // input pin for the PIR sensor
int pirStat = LOW; // we start assuming no motion is detected
int pirState = 0; // variable for reading the status, also the value
pinMode(ledPin, OUTPUT); // the LED is output
pinMode(pirPin, INPUT); // the sensor is input
void loop(){
pirState = digitalRead(pirPin); // read input value
if (pirState == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirStat == HIGH){ // if the PIR state is high, it switches on the LED and then turns low again
pirStat = LOW;
I also used this piece of code-
const int ledPin = 11; // LED
const int inputPin = 2; // input pin for the PIR sensor
const int pirState = LOW; // we start assuming no motion is detected
const int val = 0; // variable for reading the status
pinMode(inputPin, INPUT); // the sensor is input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) // check if the input is HIGH
Serial.println("Motion Detected!");
else {
(pirState = LOW);
Serial.println("Motion is gone!");
