Please help me with my RGB LEDs!
Hi all...
Before I get into my little problem, let me start by saying I've only had my Arduino for a week and I absolutely love it... I'm a total n00b when it comes to electronics so if you guys could help me out, I'd really appreciate it.
I picked up a few of these RGB LEDs: http://maplin.co.uk/Module.aspx?ModuleNo=35893
The datasheet is here: http://www.maplin.co.uk/Media/PDFs/N63AX.pdf
I've managed to get two of them working, but I've now used up all the PWM pins on my Arduino. :( I want to hook up another two and have each be able to be any colour.
I was wondering how I would go about this? Do I need to use a shift register? From what I've read that won't work with PWM. I'm really quite confused at the moment, so any help would be greatly appreciated!
Thanks...
Matt
I LOVE how every thread starts like that :).
I believe that should work.
Now, I'm pretty nooby when it comes to Shift Registers, but I have no idea why it wouldn't...
That was a quick reply! :)
I thought shift registers would only allow me to digital... To be honest, I'm completely confused... A good n00b explanation of how to do it would be awesome! :)
Cheers!
it probably wouldn't work with shift registers, unless you used the pwm as the clock, then they would all be in the exact same state...
off the top of my head I am not sure
Try to check this old thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1173831471/12
It's about using a 5940 IC which has 16 PWM channels
The reason why it wouldn't work is that PWM turns things on an off rapidly to achieve dimming. A shift register only expands the digital output capability. In order to get PWM from a shift register you would have to load the shift register very quickly at least 256 * 32 = 8192 times a second, for 8 bit PWM resolution. Then you would need the software to drive this. There would be little time to do anything else.
