Hi. I'm a Korean student who wants to learn more about processing and arduino and I am so new to this area. My team is trying to learn about processing and arduino.
What I'm trying to do is to display people's movements on LED 32*32 which are seen through kinect.
This LED has to be used with RGBMatrixPanel library and I'm new to it.
MY computer is Windows 7.
I have processing 2.2 and simpleopenNI 1.96
I'm using Arduino Mega also.
To talk about anything I will start with my code first.
I'm really sorry that our code is so messy.
This is for processing
import processing.serial.*;
import processing.opengl.*;
import SimpleOpenNI.*;
SimpleOpenNI kinect;
PImage kSM = new PImage(32,32,ARGB);
PImage kSmall = new PImage(640,480,ARGB);
byte g[] = new byte[1024];
int userMap[];
int numUsers = 0;
int arduinoPort = -1;
Serial myPort;
size(901, 800, P2D);
kinect = new SimpleOpenNI(this);
kinect.enableDepth();
kinect.setMirror(true);
kinect.enableUser();
/*String[] ports = Serial.list();
for (int i=0;i<ports.length;i++) {
println(ports[i]);
// THIS IS SPECIFIC TO THE PORT YOUR ARDUINO IS ON!!!
if (ports[i].indexOf("411") > -1 && ports[i].indexOf("tty") > -1) {
arduinoPort = i;
if (arduinoPort > -1) {
myPort = new Serial(this, Serial.list()[arduinoPort], 57600);
//String portName = Serial.list()[2]; //change the 0 to a 1 or 2 etc. to match your port
//myPort = new Serial(this, portName, 57600);
myPort = new Serial(this, "COM4", 57600);
background(128,0,0);
// give some time to wake up arduino and kinect
delay(3000);
void draw() {
background(0);
kinect.update();
image(kinect.depthImage(), 20, 120);
PVector[] depthPoints = kinect.depthMapRealWorld();
for (int y=0;y<32;y++) {
for (int x=0;x<32;x++) {
PVector currentPoint = depthPoints[(x*floor(640/32)) + ((y * floor(480/32)) * kinect.depthImage().width)];
if (currentPoint.z < 200 || currentPoint.z > 2000) {
currentPoint.z = 0;
noStroke();
fill(map(currentPoint.z, 0, 4000, 0, 255));
ellipse(680+x, 120+y, 2, 2);
numUsers = kinect.getNumberOfUsers();
if (numUsers > 0) {
numUsers = 1;
// find out which pixels have users in them
//userMap = kinect.getUsersPixels(SimpleOpenNI.USERS_ALL);
//userMap = kinect.getUsers();
userMap = kinect.userMap();
// populate the pixels array
// from the sketch's current contents
kSmall.loadPixels();
for (int i = 0; i < userMap.length; i++) {
// if the current pixel is on a user
if (userMap[i] != 0) {
// make it green
kSmall.pixels[i] = color(0, 255, 0,255);
kSmall.pixels[i] = color(0,0);
// display the changed pixel array
kSmall.updatePixels();
kSM.copy(kSmall,80,0,480,480,0,0,32,32);
image(kSM,680,120,64,64);
fill(255,0,0);
text("users: " + numUsers,10,10);
int as=10;
int ad=20;
for (int i=0;i<1024;i++) {
//ad = ad +10;
g[i] = kSM.pixels[i] == 0 ? (byte)0 : (byte)1;
text(i+" pixel:" + g[i], as,ad);
//if( i == 980 ) {
// as = as+50;
// text(i+" pixel:" + g[i], as,10);
// mask depth image to show what matrix will get
noStroke();
fill(0);
rect(20,120,80,480);
rect(580,120,80,480);
// send the data to arduino
//drawGrid();
//if (arduinoPort > -1) {
sendToArduino();
numUsers = 0;
delay(50);
void sendToArduino() {
// send data to arduino
// header
int b1 = 0x81;
int b2 = 0xc3;
myPort.write(b1);
myPort.write(b2);
// number of users
myPort.write((byte)numUsers);
myPort.write((byte)1024);
// image bytes
for (int offset=0;offset<32;offset++) {
byte rb = 0x00;
byte mask = 0x01;
for (int i=0;i<32;i++) {
if (g[i+(offset*32)] == 1) {
rb = (byte)(rb | mask);
mask = (byte)(mask << 1);
myPort.write(rb);
Processing code seem to work at least.
Next is arduino IDE
#include <Adafruit_GFX.h>
#include <RGBmatrixPanel.h>
#include <gamma.h>
#ifndef PSTR
#define PSTR // Make Arduino Due happy
#endif
#define CLK 11 // MUST be on PORTB! (Use pin 11 on Mega)
#define LAT 9
#define OE 10
#define A A3
#define B A2
#define C A1
#define D A0
const byte HEADER1 = 0x81;
const byte HEADER2 = 0xc3;
const int TOTAL_BYTES = 32 ; // 2 headers + 2 numusers + 32 imagedata
byte inBytes[32];
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false, 32);
inBytes[i] = (byte)0;
//pinMode(11, OUTPUT);
Serial.begin(57600);
//Serial.setTimeout(150);
matrix.begin();
/*// start with RGB tests (set all pixels to same color to look for bad LEDs)
matrix.fillScreen(matrix.Color333(255,0,0));
matrix.fillScreen(matrix.Color333(0,255,0));
matrix.fillScreen(matrix.Color333(0,0,255));
matrix.fillScreen(0);
// Show white corners just to make sure we're addressing LEDs by number correctly (0-15)
matrix.drawPixel(0,0,matrix.Color333(255,255,255));
matrix.drawPixel(31,0,matrix.Color333(255,255,255));
matrix.drawPixel(0,31,matrix.Color333(255,255,255));
matrix.drawPixel(31,31,matrix.Color333(255,255,255));
// wait for all bytes
if ( Serial.available()>= TOTAL_BYTES)
Serial.print("input data ok");
Serial.write(Serial.read());
if( Serial.read() == HEADER1)
if (Serial.read() == HEADER2) {
// next byte is number of users
// for now we only care if it's not 0 (zero)
char inByte = Serial.read();
int numUsers = inByte - '0'; // convert byte to number
Serial.read(); // 255 byte
// read rest of packet
for (int j=0;j<32;j++) {
inBytes[j] = Serial.read();
if (numUsers != 0) {
drawUser();
// we have 0 users
// clear the screen
// no serial data...
// This code is to light up every corner on LED if there's no serial data
void drawUser() {
// clear matrix
// iterate over byte array
// for each byte, check each bit and and turn pixels on where the bit is 1
int x = 0;
int y = 0;
byte b = inBytes[j];
for (int i=0;i<8;i++) {
if (bitRead(b,i) == 1) {
matrix.drawPixel(x,y,matrix.Color333(255,255,255));
matrix.drawPixel(x,y,0);
x++;
if (x > 31) {
y++;
x = 0;
Sorry that it's a real mess.
Alright. Here is what I want to say. Arduino Mega seems to receive the values as you can see in the picture #1.
But when you see LED on picture #2, it seems it's not receiving any serial data because I made the code to light up every corner on LED if there are no serial data.
This is ironic for me. Can anybody help me please.
Picture #3 is a picture on PC monitor when I ran processing
