PLEASE HELP ME
I’m doing a project about toggle 3 leds with 3 buttons and my code is error. I don’t know why my code is error. Thankyou
on_off_LED.ino (1.54 KB)
Please post the error message that you get.
...R
Please post your code too.
int pinButton = 5;
int pinButton = 6;
int pinButton = 8;
3 variables with the same name?
Then this
int LED2 = 2;
int LED4 = 4;
int LED7 = 7;
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
and
int stateButton5;
int stateButton6;
int stateButton8;
  stateButton = digitalRead(pinButton5);
  stateButton = digitalRead(pinButton6);
  stateButton = digitalRead(pinButton8);
and
  previous == stateButton5;
  previous == stateButton6;
  previous == stateButton8;
Just wondering, how many Examples from the IDE have you tried out?
Do you know that each has a page on the Arduino site with explanations of the code and wiring?
We can snigger - but OP, you will too in a few weeks, once you understand the language and syntax of the commands!
EDIT: Added OP's original code listing - as [u]CODE[/u] !
/* sketch 3
turn on a LED when the button is pressed and let it on
until the button is pressed again
int pinButton = 5;
int pinButton = 6;
int pinButton = 8;
int LED2 = 2;
int LED4 = 4;
int LED7 = 7;
int stateLED2 = LOW;
int stateLED4 = LOW;
int stateLED7 = LOW;
int stateButton5;
int stateButton6;
int stateButton8;
int previous5 = LOW;
int previous6 = LOW;
int previous8 = LOW;
long time = 0;
long debounce = 200;
  pinMode(pinButton5, INPUT);
  pinMode(pinButton6, INPUT);
  pinMode(pinButton8, INPUT);
//LED 2
  if(stateButton5 == HIGH && previous5 == LOW && millis() - time > debounce) {
    if(stateLED2 == HIGH){
      stateLED2 = LOW;
       stateLED2 = HIGH;
       time = millis();
// LED 4
if(stateButton6 == HIGH && previous6 == LOW && millis() - time > debounce) {
    if(stateLED4 == HIGH){
      stateLED4 = LOW;
       stateLED4 = HIGH;
       time = millis();
// LED 7
if(stateButton8 == HIGH && previous8 == LOW && millis() - time > debounce) {
    if(stateLED7 == HIGH){
      stateLED7 = LOW;
       stateLED7 = HIGH;
       time = millis();
  digitalWrite(LED2, stateLED2);
  digitalWrite(LED4, stateLED4);
  digitalWrite(LED7, stateLED7);
I'm not laughing. I just want to raise the OP's awareness enough to get truly started on a clearer path. It takes some digging in the Arduino site to find the information needed even with the library at your fingertips.
