Please help!! Multiple errors on 'simple' code!!
int ledPin = 13;
pinMode (ledPin , OUTPUT);
boolean input = 'off';
  if (Serial.available()){
  'input' = Serial.read();
  if ('input' = 'on'){
   digitalWrite('ledPin' , HIGH);
  digitalWrite('ledPin' , LOW);
I get the following errors:
LED_CONTROL.ino: In function 'void loop()':
LED_CONTROL:10: error: lvalue required as left operand of assignment
LED_CONTROL:13: error: lvalue required as left operand of assignment
Please help!
Thanks in advanced
  • Thomas
Get rid of all those single quotes and take a look at some of the serial communication examples.
ledPin also needs to be declared in the global scope if you want to access it from both setup and loop
You are getting a bunch of errors because you are making things up as you go along. Look at the many example sketches to see what a sketch should look like.
Don't quote variable names. It turns them into character constants. You can't assign a new value to a character constant (which is why it is called a 'constant').
This will set the variable named "input" to the value 1. If you want the value 0, use 0 or something equivalent, like false.
johnwasser:
All Fixed! Thanks!!
Did you fix this too?
Need == for a comparison test
CrossRoads:
No, didn't fix this, but i have now!
