Please help, my sr501+wemos keep loop "No motion"" Motion detected"
Please help, my sr501+wemos keep loop "No motion" " Motion detected"
-----------MY OUTPUT---------------
01:58:20.564 -> Motion detected ALARM
01:58:22.576 -> No motion
01:58:28.582 -> Motion detected ALARM
01:58:30.586 -> No motion
01:58:36.559 -> Motion detected ALARM
01:58:39.576 -> No motion
01:58:44.595 -> Motion detected ALARM
01:58:47.575 -> No motion
01:58:58.584 -> Motion detected ALARM
01:59:01.602 -> No motion
01:59:15.587 -> Motion detected ALARM
01:59:17.589 -> No motion
01:59:23.587 -> Motion detected ALARM
01:59:26.607 -> No motion
01:59:32.613 -> Motion detected ALARM
01:59:35.602 -> No motion
-----------MY OUTPUT end ---------------
---------------------------------Orginal code from internet:------------------------------------------
// Author: Vishal Pal Chaudhary
// Bitbucket: Bitbucket
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
const char* ssid = "Your SSID";
const char* password = "Your password";
#define mqtt_server "MQTT Server hostname / IP"
const int mqtt_port = 1883;
#define mqtt_user "MQTT Username"
#define mqtt_password "MQTT Password"
#define sensor_name "Your_sensor_name" //Must be unique (Fall back already handled with chip id)- Vishal
int pirPin = D6; // Put the data pin number where u connected the pir sensor. D6 in my case
int val;
int state = 0;
String wemos_hostname;
String mqtt_state_topic;
String mqtt_availability_topic;
String mqtt_config_topic;
WiFiClient espClient;
PubSubClient client(espClient);
// OTA CODE //
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
wemos_hostname = sensor_name "-" + String(ESP.getChipId(), HEX);
ArduinoOTA.setHostname(String(wemos_hostname).c_str());
ArduinoOTA.onStart( {
Serial.println("Start");
ArduinoOTA.onEnd( {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
// OTA CODE //
mqtt_config_topic="homeassistant/binary_sensor/" sensor_name "/config";
mqtt_state_topic="homeassistant/binary_sensor/" sensor_name "/state";
mqtt_availability_topic="homeassistant/binary_sensor/" sensor_name;
//wemos_hostname += String(ESP.getChipId(), HEX);
Serial.println("hostname="+wemos_hostname);
pinMode(LED_BUILTIN, OUTPUT);
// delay(5000);
// WiFi.printDiag(Serial);
client.setServer(mqtt_server, mqtt_port);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
// If you do not want to use a username and password, change next line to
// if (client.connect("ESP8266Client")) {
char will_message [] = "offline";
if (client.connect(String(wemos_hostname).c_str(), mqtt_user, mqtt_password,String(mqtt_availability_topic).c_str(),0,1,will_message)) {
client.publish(String(mqtt_config_topic).c_str(), String("{"name":"" sensor_name "", "device_class": "motion"}").c_str(), true); //Autodiscovery packet sent with retained flag.
client.publish(String(mqtt_availability_topic).c_str(), String("online").c_str(), true);
Serial.println("connected");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void publish_message(int state){
//Serial.println("/home/" sensor_name "/motion");
if(state)
client.publish(String(mqtt_state_topic).c_str(), String("ON").c_str(), true);
client.publish(String(mqtt_state_topic).c_str(), String("OFF").c_str(), true);
ArduinoOTA.handle();
if (!client.connected()) {
reconnect();
client.loop();
val = digitalRead(pirPin);
//low = no motion, high = motion
if (val == LOW)
//Serial.println(state);
if(state == 1)
state = 0;
publish_message(state);
//client.publish("/home/"+sensor_name+"/motion", String(state).c_str(), true);
Serial.println("No motion");
pinMode(LED_BUILTIN, 0);
if(state == 0)
state = 1;
Serial.println("Motion detected ALARM");
pinMode(LED_BUILTIN, 1);
delay(1);
Please use the IDE's auto format tool before posting code.
Please remember to use code tags when posting code.
