Hi I hope someone can help me, I am really new to the arudino and its been a steap learning curve , I am working with a SH1106 display and have eventually get it working how I wanted , using other peoples code.
I have 4 images running on a loop to make like a gif and thats working great but before the gif program starts I hould like to add some text with a 5000ms delay and then only display the gif.
If someone could help me it would be much apreciated and will help me learn
thanks in advance
here is my code so far , i have had to cut out 3 frames because of post character limits
#include “U8glib.h”
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NO_ACK); // Display which does not send ACK
int frame = 0;
const unsigned char PROGMEM frame1 = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x07, 0x08, 0x78,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0xFC, 0x39, 0xC0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x83, 0x80, 0x27, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x8E, 0x00, 0x7C, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x98, 0x03, 0xC0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x0E, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x78, 0x07, 0xE0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x81, 0xC0, 0x00, 0x20,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x86, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x8C, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x90, 0x07, 0xFF, 0xF8,
0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x81, 0xFC, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x82, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x9E, 0x00, 0x01, 0xF0,
0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0xFF, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x0F, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x03, 0xFF, 0xC0, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x18, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0xFF, 0xF0, 0x00, 0x03, 0xFF, 0x9F, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x1F, 0xFF, 0xF8, 0x00, 0x0F, 0xFF, 0x80, 0x01, 0xF8, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x7F, 0x00, 0xFE, 0x00, 0x0F, 0xFF, 0xA0, 0x00, 0x0F, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0xFC, 0x00, 0x3F, 0x00, 0x0F, 0x0F, 0xBE, 0x00, 0xC1, 0x80,
0x00, 0x00, 0x00, 0x00, 0x78, 0x01, 0xF8, 0x00, 0x1F, 0x80, 0x0F, 0x0F, 0x81, 0x80, 0x70, 0xE0,
0x00, 0x00, 0x00, 0x00, 0xF8, 0x01, 0xE0, 0x00, 0x07, 0x80, 0x07, 0x0F, 0x80, 0xE0, 0x1E, 0x30,
0x00, 0x00, 0x00, 0x00, 0xF0, 0x03, 0xEE, 0x00, 0x77, 0xC0, 0x07, 0x00, 0x00, 0x38, 0x03, 0xC0,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0xCF, 0x00, 0xF3, 0xE0, 0x07, 0x00, 0x00, 0x0F, 0xC0, 0x70,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x87, 0x81, 0xE1, 0xE0, 0x07, 0x80, 0x00, 0x00, 0x70, 0x10,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x83, 0xC3, 0xC1, 0xF0, 0x07, 0x80, 0x00, 0x00, 0x0C, 0x00,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x01, 0xE7, 0x80, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x00, 0xFF, 0x00, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x01, 0xC0,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x00, 0x7E, 0x00, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x70,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x00, 0x3C, 0x00, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x18,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x00, 0x3C, 0x00, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x00, 0x7E, 0x00, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x0F, 0x00, 0xFF, 0x00, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xC0, 0x0F, 0x01, 0xE7, 0x80, 0xF0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x83, 0xC3, 0xC1, 0xF0, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0x87, 0x81, 0xE1, 0xE0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x07, 0xCF, 0x00, 0xF3, 0xE0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xF0, 0x03, 0xEE, 0x00, 0x77, 0xC0, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x78, 0x01, 0xE0, 0x00, 0x07, 0x80, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x78, 0x01, 0xF8, 0x00, 0x1F, 0x80, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0xFC, 0x00, 0x3F, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x7F, 0x00, 0xFE, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x1F, 0xFF, 0xF8, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x0F, 0xFF, 0xF0, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x03, 0xFF, 0xC0, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0xFF, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x07, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x00, 0x00, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x00, 0x1F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x81, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
void draw()
if(frame==0)
u8g.drawBitmapP( 0, 0, 16, 64, frame1);
else if (frame == 1)
u8g.drawBitmapP( 0, 0, 16, 64, frame2);
else if(frame == 2)
u8g.drawBitmapP( 0, 0, 16, 64, frame3);
else if(frame == 3)
u8g.drawBitmapP( 0, 0, 16, 64, space4);
void setup(void) {
void loop(void) {
u8g.firstPage();
do{
draw();
} while(u8g.nextPage());
frame ++;
if(frame>3)
frame = 0;
delay(200);
