Hello Guys,
I am getting some error whenever I am running any given examples of RF Audio library. The error is as below. And I have no idea how to solve this error.
C:\Program Files (x86)\Arduino\libraries\RF24Audio-master\RF24Audio.cpp: In function 'void __vector_11()':
C:\Program Files (x86)\Arduino\libraries\RF24Audio-master\RF24Audio.cpp:460:4: error: 'radio' was not declared in this scope
radio.writeFast(&buffer,32);
Error compiling.
The getting started code is as bellow.
/* RF24 Audio Library TMRh20 2014
This sketch is intended to demonstrate the basic functionality of the audio library.
Requirements:
2 Arduinos (Uno,Nano,Mega, etc supported)
2 NRF24LO1 Radio Modules
1 or more input devices (microphone, ipod, etc)
1 or more output devices (speaker, amplifier, etc)
Setup:
1. Change the CE,CS pins below to match your chosen pins (I use 7,8 on 328 boards, and 48,49 on Mega boards)
2. Upload this sketch to two or more devices
3. Send serial commands via the serial monitor to control transmission and volume (volume only affects receiving devices)
Default Pin Selections:
Speaker: pins 9,10 on UNO, Nano, pins 11,12 on Mega 2560
Input/Microphone: Analog pin A0 on all boards
#include <RF24.h>
#include <SPI.h>
#include <RF24Audio.h>
#include "printf.h" // General includes for radio and audio lib
RF24 radio(7,8); // Set radio up using pins 7 (CE) 8 (CS)
RF24Audio rfAudio(radio,1); // Set up the audio using the radio, and set to radio number 0
Serial.begin(115200); // Enable Arduino serial library
printf_begin(); // Radio library uses printf to output debug info
radio.begin(); // Must start the radio here, only if we want to print debug info
radio.printDetails(); // Print the info
rfAudio.begin(); // Start up the radio and audio libararies
if(Serial.available()){ // Receive and analyze incoming serial data
switch(Serial.read()){
case 'r': rfAudio.transmit(); break; // Send an r or an s over serial to control playback
case 's': rfAudio.receive(); break;
case '=': rfAudio.volume(1); break; // Control volume by sending = or - over serial
case '-': rfAudio.volume(0); break;
Serial.println("test");
/* Documentation and References:
References:
All Library documentation: http://tmrh20.github.io/
New (2014) RF24 Audio Library: https://github.com/TMRh20/RF24Audio
Optimized (2014) RF24 Lib Source Code: https://github.com/TMRh20/RF24
Optimized (2014) RF24 Network Lib: https://github.com/TMRh20/RF24Network
Please help me.. I have very less time left to finish it.
thank you...
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
