We are use 3 nema 23 motors and 3 tb6600 motor drivers.And also use load cell and hx11 module.
Our target is get user input to 3 of 1 motor number (1/2/3) and target weight (in grams).
In example user input 2,500 , then load cell reading until reach 500 g that number 2 motor only will work.
We are trying many time in coding that program not perfectly working.
So can you are help to code our project
No, not out the information You give.
Please read and use this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
Write in your natural language, and use translate.google.com for the language you prefer to reach.
You have:
- three motors (need datasheet for these)
- three TB6600 (https://www.makerguides.com/wp-content/uploads/2019/10/TB6600-Manual.pdf)
- HX711 load cell module (https://www.digikey.com/htmldatasheets/production/1836471/0/0/1/hx711.html)
- you tried using 2500 as the calibration offset? scale.set_scale(2500.f);
Is this the example you were using? HX711/examples/HX711_full_example/HX711_full_example.ino at master · bogde/HX711 · GitHub
