please help trying to add a Delay wont work
//this sketch will allow you to bypass the Atmega chip // and connect the Ultimate GPS directly to the USB/Serial // chip converter.
// Connect VIN to +5V// Connect GND to Ground // Connect GPS RX (data into GPS) to Digital 0 // Connect GPS TX (data out from GPS) to Digital 1 // delay (10000);
delay (10000)
void setup() {} void loop() {}
getting this error ror: expected constructor, destructor, or type conversion before '(' token expected constructor, destructor, or type conversion before '(' token
You have to include the delay() within the code either in the setup() function or in the loop() function.
Having nothing in your code except a delay() won't achieve much.
...R
thanks robin but still doesn't work
// Connect VIN to +5V// Connect GND to Ground // Connect GPS RX (data into GPS) to Digital 0 // Connect GPS TX (data out from GPS) to Digital 1 // delay (10000); (puases for 10 seconds)
void setup() {} (delay 10000); void loop
No, you have to put all function calls, including delay, inside a function. Here you have just moved it in between two functions.
Try this, it won't do anything but will at least compile. Notice the difference. The delay call is now between the { and } that define the setup function.
(delay 10000);
void loop
(delay 10000);Ummm ?
It needs to be like this
  delay (10000);
You should look at several of the examples that come with the Arduino IDE and carefully study how the code is laid out in them.
…R
To "work", code has to compile and run.
UKHeliBob:
Sorry. Got in a hurry with the cut and paste.
I guessed so because I know you know better !
Where did you find this alleged "sketch"?
Leonides123: delay (10000)
Find a C or C++ tutorial. Programming is not like making a salad.
