Circuit diagram :
int A=3;
int B=5;
int C=9;
int D=10;
int Speed=100;
String Command;
pinMode(A,OUTPUT);
pinMode(B,OUTPUT);
pinMode(C,OUTPUT);
pinMode(D,OUTPUT);
while (Serial.available()==0) {
Command=Serial.readString();
Serial.println(Command);
if (Command=="forward") {
analogWrite(A,Speed);
analogWrite(B,LOW);
analogWrite(C,LOW);
analogWrite(D,Speed);
if (Command=="stop") {
analogWrite(A,LOW);
analogWrite(B,LOW);
analogWrite(C,LOW);
analogWrite(D,LOW);
if (Command=="backward") {
analogWrite(A,LOW);
analogWrite(B,Speed);
analogWrite(C,Speed);
digitalWrite(D,LOW);
if (Command=="right") {
analogWrite(A,LOW);
analogWrite(B,LOW);
analogWrite(C,LOW);
if (Command=="left") {
analogWrite(B,LOW);
analogWrite(C,LOW);
analogWrite(D,LOW);
Error when Upload it ![]()
Arduino: 1.8.19 (Windows 7), Board: "Arduino Uno"
Sketch uses 4156 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 236 bytes (11%) of dynamic memory, leaving 1812 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc1
option enabled in File -> Preferences.
