arulhakuto:
anyone know why this logic does not work or is there another logic for substitute this logic?
Why is the Title for this question “Subroutine” ?
If you use a title that describes your problem you may catch the interest of people with useful advice.
If you modify your original post you can edit the title.
This is not a very sensible way to name your variables.
You already have global variables called PIN_8 and PIN_7 but the compiler will use this code to create local variables of the same name within your function. It will work fine - the compiler won't care. But it will be confusing for you.
To add to the confusion you refer to the global variable PIN_4 in the same function.
In void awal " if ( keadaantegangan2 == HIGH ||keadaantegangan3 == HIGH )
digitalWrite (PIN_4, HIGH );
delay (1000); } " this comand is not executed in my arduino…
i dont know why ?
Aside from the issues with useless names for variables, passing global values to functions, etc. that have been pointed out, but not addressed, there is a serious lack of debug code. What is being read from the pins? How are the switches actually wired?
Debug-by-guess takes FAR long then debug-with-facts. Get some facts!
Perhaps your PIN_8 and PIN_7 are not high when you read them.
You realise you’ve got a delay of 1 second towards the end of your loop function. (yes the delay executes EVERY time, even though you’ve indented it). Also you’ve got another delay of 1 second at the end of your awal function.
So you’re only making your test of PIN_8 and PIN_7 for a fleeting moment, once every two seconds.
Can you please post a copy of your sketch, using code tags?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Before you repost your sketch in code tags, in the IDE select TOOLS then AUTO FORMAT to make your sketch easier to read.
At this point please oblige us with the above request.
arulhakuto:
delay (1000); } " this comand is not executed in my arduino..
i dont know why ?
As a tail part of previous code (SEE FULL CODE ) this is syntactically correct.
However, the logic may be not what you want.
The digitalWrite (PIN_4, HIGH ); will not execute if the If() evaluates to false.
One way to check WHERE your code goes astray would be to temporary add serial
.... previous code
Serial.print("HERE if true");
digitalWrite (PIN_4, HIGH ); // here if false
delay (1000);
arulhakuto:
i dont know why ?
