I set ADC prescale = 128 by using the following code:
Serial.begin(9600); // use the serial port
pinMode(refInput, INPUT);
pinMode(finalInput, INPUT);
pinMode(motorControl, OUTPUT);
ADCSRA |= (1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0); //set adc prescaler=128
ADMUX = 0x40; // use adc0
ADCSRA |= (1<<ADATE); //enable auto trigger
ADCSRA |= (1<<ADEN); //enable ADC
ADCSRA |= (1<<ADSC); //start ADC measurements
Then I sample the sound with the following code:
for (int i = 0 ; i < 512 ; i += 2) { // save 256 samples
while(!(ADCSRA & 0x10)); // wait for adc to be ready
ADCSRA |=(1<<ADSC); //start ADC measurements
byte m = ADCL; // fetch adc data
byte j = ADCH;
int k = (j << 8) | m; // form into an int
k -= 0x0200; // form into a signed int
k <<= 6; // form into a 16b signed int
fft_input[i] = k; // put real data into even bins
fft_input[i+1] = 0; // set odd bins to 0
}//end of for
Everything works in the way I want it to. But now I need at least two digital pins to use digitalRead(); I found out all the digital pins stopped reading, but digitalWrite() still works.
Do you guys have any idea what is going on?
If audio section is the right place to ask this type of question, please point me to the correct section.
Thank you guys for the help in advance; Any suggestion and reply is welcome and appreciated.
#define LOG_OUT 1 // use the log output function
#define FFT_N 256 // set to 256 point fft
#include <FFT.h> // include the library
int refFrequency = 0;
int finalFrequency = 0;
int errorFrequency = 0;
int refState = 0;
int finalState = 0;
const int refInput = 9;
const int finalInput = 10;
int bin = 0;
int frequency = 0;
int resolution = 9615 / 256;
int maxLogOut = 0;
int motorControl = 11;
while(1) { // reduces jitter
cli(); // UDRE interrupt slows this way down on arduino1.0
//sampling
byte j = ADCH;
}//end of for
//FFT
fft_window(); // window the data for better frequency response
fft_reorder(); // reorder the data before doing the fft
fft_run(); // process the data in the fft
fft_mag_log(); // take the output of the fft
sei();
maxLogOut = 0;
for(int i = 1; i < 128; i++){
if(fft_log_out[i] > maxLogOut && fft_log_out[i] > 150){
maxLogOut = fft_log_out[i];
bin = i;
}//end of if
}//end of for
frequency = bin * resolution;
//if digital pin 9 is high, set the reference frequency
//if digital pin 10 is high, set the final frequency
refState == digitalRead(refInput);
finalState == digitalRead(finalInput);
if(refState == HIGH){
refFrequency = frequency;
Serial.print("----------------------");
} else if(finalState == HIGH){
finalFrequency = frequency;
} //end of else if
//debug
Serial.print("frequency: ");
Serial.print(frequency);
Serial.print(" | ");
Serial.print("reference frequency: ");
Serial.print(refFrequency);
Serial.print("final frequency: ");
Serial.print(finalFrequency);
Serial.print("error frequency: ");
Serial.println(errorFrequency);
//motor control
}//end of while
}//end of loop
It doesn't work because Serial.print("----------------------"); is not excuted after I connect digital pin 9 to 5V. I need to have a control over the reference and final frequency in order to have a feedback path, then do the motor control
