Good day to everyone.
I just bought an 3G/GPRS shield so I can send sms, mails, GPS position... I search in the internet how to ask for date (day and hour) cause I want to sen the date in the sms.
In every web I found they said that the command is:
"AT+CCLK"
And this command should return me something like this:
"+CCLK: yy/mm/dd hh:mm:ss"
The problem is that i don't know how to use it. I try in different ways with out success. It could be something like this??
I tried to put that in the final part of my code (where I chose the data to send in the sms) but I receive "AT+CCLK" in my phone, not the hour...Thanks for your time again Paul...
I write the Serial.print("AT+CCLK"); in "void loop2" but I don´t get the hour. With Serial.print("AT+CMGS=""); I send the sms to a phone number whit out problem but with AT+CCLK I can´t get what I want...
This is the code (you help me with it in another topic):
#include <Keypad.h>
//VARIABLES ENVIO DATOS
int led = 13;
int onModulePin = 2; // Definimos el Pin 2 para activar o desactivar el modulo 3G (sin pulsar el botón)
int timesToSend = 1; // Numero de sms a enviar
int count = 0;
char phone_number[]="*********"; // ********* numero que recibirá el sms
//VARIABLES TECLADO
const byte ROWS = 4; //4 filas
const byte COLS = 3; //3 columnas
char keys[ROWS][COLS] = {
'1','2','3' }
'4','5','6' }
'7','8','9' }
'*','0','#' }
byte rowPins[ROWS] = {
7, 6, 5, 4}; // reserva de memoria en bytes, conectar a los pines de filas del teclado
byte colPins[COLS] = {
10, 9, 8}; // reserva de memoria en bytes, conectar a los pines de columnas del teclado
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char serialnumber[10]="6103722";
char usuario1[]="111#";
char usuario2[]="222#";
char usuario3[]="333#";
char usuario4[]="444#";
char usuario5[]="555#";
char attempt[]="0000"; // usado para comparar
int z=0;
int sal1 = 11; // salida led verde pin 11
int sal2 = 12; // salida led rojo pin 12
char attempt2[5]="0000";
//PROGRAMA
pinMode(sal1, OUTPUT);
pinMode(sal2, OUTPUT);
Serial.begin(115200); //Configura la velocidad del puerto serie
keypad.setHoldTime(150); // Tiempo de pulsado de boton. Default is 1000mS
keypad.setDebounceTime(30); // Tiempo de rebote de bootn. Default is 50mS
Serial.println(" Introduzca PIN: ");
void leds()
if (sal1 == LOW)
sal2 = HIGH;
sal2 = LOW;
void checkPIN()
Serial.print("attempt: [");
Serial.print(attempt);
Serial.print("]");
int correct = 0;
if(strcmp(attempt, usuario1) == 0)
correct = 1;
else if(strcmp(attempt, usuario2) == 0)
correct = 2;
else if(strcmp(attempt, usuario3) == 0)
correct = 3;
else if(strcmp(attempt, usuario4) == 0)
correct = 4;
else if(strcmp(attempt, usuario5) == 0)
correct = 5;
if ( correct=!0)
Serial.println("PIN OK");
digitalWrite(11, HIGH); // activa un contacto
for (int zz=0; zz<=4; zz++) // borrar el último código introducido
attempt[zz]=0;
switchModule();
setup2();
loop2();
Serial.println("PIN erroneo");
digitalWrite(12, HIGH); // activa un contacto
digitalWrite(12, LOW);
attempt[zz]=0;
setup();
void readKeypad()
char key = keypad.getKey();
if (key != NO_KEY)
switch(key)
case '*':
z=0;
digitalWrite(11, LOW);
setup();
case '#':
delay(50);
Serial.println(" ");
checkPIN();
default:
attempt[z]=key;
z++;
attempt[z] = '\0'; // Add this to keep attempt NULL terminated (after making attempt larger)
Serial.print("*");
leds();
readKeypad();
void switchModule(){
digitalWrite(onModulePin,HIGH); //Para activar el módulo 3G, debemos enviarle un pulso de 2sg por el pin número 2 (lo mismo para apagar)
Serial.println("Activando modulo 3G...");
delay(2000);
digitalWrite(onModulePin,LOW);
Serial.println("Modulo 3G activado...");
void setup2(){
Serial.begin(115200); //Configuramos puerto UART
delay(2000);
pinMode(led, OUTPUT);
pinMode(onModulePin, OUTPUT);
for (int i=0;i< 5;i++){
delay(5000);
Serial.println("AT+CMGF=1"); //Seleccionamos el formato del sms (0=PDU 1=texto)
delay(100);
void loop2(){
while (count < timesToSend){
delay(1500);
Serial.print("AT+CMGS=\""); // send the SMS number
Serial.print(phone_number);
Serial.println("\"");
delay(1500);
Serial.print("Numero de serie: ");
Serial.println (serialnumber);
delay(1500);
Serial.print("Usuario: ");
Serial.println (attempt);
Serial.write(0x1A); //sends ++
Serial.write(0x0D);
Serial.write(0x0A);
delay(5000);
count++;
I read some manual on the net before post anything in the forum but any of them solve my problem. Maybe it tooks too much time to receive signal grom the GPS... Right now i'm trying to get the date with a DSL1307.
Thanks for your answer.
dgelectron:
