Please Help with my code
i need to make an led stay on for 1 second at a regular interval of one second using the millis(); function
here is the code i have
const int ledPin =  13;
int ledState = LOW;
long previousMillis = 0;
long interval = 1000;
long space = 3000;
  pinMode(ledPin, OUTPUT);
  unsigned long currentMillis = millis(); // Store the current time
 Serial.println(currentMillis);
  if(currentMillis - previousMillis > interval && currentMillis - previousMillis + 1000 < space) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;   // move current time into previous time
    digitalWrite(ledPin, HIGH);
  else {
  digitalWrite(ledPin,LOW);
the led needs to stay on when the time is between 1000 millis and 2000 millis. i need to use this code in another project when i con get it going
happydays4311:
There is an example that comes with the IDE that does exactly that.
File - Examples - Digital - Blink Without Delay
I think you've got a few problems, but the most immediate is that the way you have written the code, the LED will only go high for a cycle of the loop, before immediately being set to LOW the next time through the loop.
The
also needs a millis() time guard around it. Only set it LOW after the LED has been on for the time interval you want.
semi-messy example of real time principles at work.
this blinks and watches for user single digit input through serial monitor.
working example:
const byte ledPin =  13;
byte ledState = LOW;
unsigned long previousMillis, currentMillis, waitMillis = 1000;
unsigned long markMillis = 1000, spaceMillis = 2000;
  Serial.begin( 115200 ); // make sure that serial monitor is set to 115200 baud
  Serial.println( "\n\n  Enter 1 - 9 to change the blink speed/restart blink" );
  Serial.println( "  Enter 0 to stop blink\n" );
inline void blink()
  if ( waitMillis > 0 )
    if(currentMillis - previousMillis >= waitMillis)
      previousMillis += waitMillis;   // start time corrected if late
      ledState = !ledState;
      if ( ledState )
        waitMillis = markMillis; // led will be on for mark time
        waitMillis = spaceMillis; // led will be off for space time
      digitalWrite(ledPin, ledState);
inline void usrKey() // read one digit and set blink on time
  static char ch;
  if ( Serial.available()) // this part is for you to figure out
    ch = Serial.read();
    Serial.println( ch );
    if ( ch >= '1' && ch <= '9' )
      markMillis = waitMillis = (unsigned long) ( ch - '0' + 1 ) * 100UL;
      spaceMillis = 2UL * markMillis;
    else if ( ch == '0' )
      waitMillis = 0UL; // 0 makes 0% stop
  usrKey();
  blink();
The demo several things at a time illustrates the use of millis() to mange timing for some LEDs.
...R
