Please help with n24l01
I am trying to send the state of multiple buttons at the same time .Been trying to find a solution for days with no luck .
CODE FOR TX
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
int msg0[1];
int msg1[1];
int msg2[1];
int msg3[1];
RF24 radio(9,10);
const uint64_t pipe = 0xE8E8F0F0E1LL;
int SW1 = 2;
int SW2 = 3;
int SW3 = 4;
int SW4 = 5;
void setup(void){
radio.begin();
radio.openWritingPipe(pipe);}
void loop(void){
if (digitalRead(SW1) == HIGH){
msg[0] = 1;
radio.write(msg, 1);}
if (digitalRead(SW2) == LOW){
msg1[0] = 2;
radio.write(msg1, 2);}
if (digitalRead(SW3) == LOW){
msg2[0] = 3;
radio.write(msg2, 3);}
if (digitalRead(SW4) == LOW){
msg3[0] = 4;
radio.write(msg3, 4);}
CODE FOR RX
#include <SPI.h>
#include <RF24.h>
int msg0[1];
int msg1[1];
int msg2[1];
int msg3[1];
RF24 radio(9,10);
int LED1 = 2;
int LED2 = 3;
int LED3 = 4;
int LED4 = 5;
void setup(void){
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);}
void loop(void){
if (radio.available()){
bool done = false;
while (!done){
radio.read(msg0, 1);
Serial.println(msg0[0]);
if (msg0[0] == 1){delay(1);digitalWrite(LED1, LOW);}
else {digitalWrite(LED1, HIGH);}
delay(1);
radio.read(msg1, 2);
Serial.println(msg1[0]);
if (msg1[0] == 2){delay(1);digitalWrite(LED2, LOW);}
else {digitalWrite(LEd2, HIGH);}
delay(1);
radio.read(msg2, 3);
if (msg2[0] == 3){delay(1);digitalWrite(LED3, LOW);}
else {digitalWrite(LD#, HIGH);}
delay(1);
radio.read(msg3, 4);
if (msg3[0] == 4){delay(1);digitalWrite(LED4, LOW);}
else {digitalWrite(LED4, HIGH);}
delay(1);
You did not bother to search in this forum or you would have found Simple nRF24L01+ 2.4GHz transceiver demo
You did not bother to read Read this before posting a programming question ....
You did not bother to look at the examples of the library.
Your code is one of the most unsensible tries I have encoutered for quite a time.
I have seen the links you have posted .
I just dont get it .
I dont see where it is reading any states of pins and sending them
I understand some .
I have been struggling with this for a few days
I know my coding sucks ,I am a hardware guy not software
This is my first attempt to use radios .
I have been reading all I can on bitWrite and bitRead funtions
Just cant figure out how to use it and send all states of the buttons at one time.
Thats why I am reaching out for help.
Any help would be help for
You can send 32 bytes at a time (read the datasheet) so why bother with bits?
One method would be something like:
struct Pack {
  bool fireButtonPressed;
  bool boosterOn;
  bool shieldsDown;
  bool brainMalfunction;
} packet;
  radio.write(&packet, sizeof(packet));
vitals817:
Both links point to spoon-feed material... :confused:
Like this ?
IF so how would it work on the rx side?
Thanks for the help
#include <SPI.h>
#include <RF24.h>
RF24 radio(9,10);
int fireButtonPressed = 2;
int boosterOn = 3;
int shieldsDown = 4;
int brainMalfunction = 5;
void setup(void){
radio.begin();
void loop(void){
struct Pack {
bool boosterOn;
bool shieldsDown;
} packet;
radio.write(&packet, sizeof(packet));}
Is the compiler happy? No warnings? Does it work?
(Hint: your code will flood the channel with junk, I see no reason to receive that)
There are examples in the link I posted, use them if you don't have a clue.
BTW Where are your code tags? (That is explained in the other link I posted...)
vitals817:
Like this ?
Make life easy for yourself (and us). Get the first example in my Simple nRF24L01+ Tutorial working without any changes.
When that is working reliably then start extending it to include your own data structure.
...R
