Please help with rocket project!
Help with rocket project.
Good evening gents (and ladies).
I need some help rather urgently I’m afraid. I have been programming a black box for a water rocket and up untill now it has been going rather well. It records data from an accelerometer onto a Micro SD card. However I am having serious trouble with the parachute deployment code. Basically when I read an arbitrary value on the Z axis I want a short pause, then have the output pin go high. I cannot simply use a delay as this would disrupt my data readings, so I have resolved to use millis timers. The section of code I am having an issue with is as follows:
#include <Wire.h>
#include <SparkFun_MMA8452Q.h>
#include <SPI.h>
#include <SD.h>
MMA8452Q accel;
const int chipSelect = 4;
String strData ="";
unsigned long previousMillis = millis();
Serial.begin(4800);
accel.init();
pinMode(7, OUTPUT);
SD.begin(chipSelect);}
if (accel.available()) {
accel.read();
defData();
Serial.println(strData);}
String dataString = "";
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (accel.cz<0.000){
unsigned long currentMillis = millis() - previousMillis;
if ((currentMillis - previousMillis) >= 2000) {
Serial.println("chute deployed");
digitalWrite(7,HIGH);}}
if (dataFile) {
dataFile.println(strData);
dataFile.close();
}else{
Serial.println("error opening datalog.txt");}}
void defData()  {
String strTime = String(millis());
String strX = String(accel.cx,3);
String strY = String(accel.cy,3);
String strZ = String(accel.cz,3);
strData = String(strTime + "," + strX + "," + strY + "," + strZ);}
So far I have been able to make the LED go high when I tilt the board, however the delay hasn’t worked as intended. Can anyone please help me? :frowning:
We need to see all the code and posted correctly using code tags.
Defining the previousMillis variable in the loop compleatly deletes the object of having it because it is wiped every time the loop goes round. Also setting it to the current time is not what you want to do is it?
I’ve since updated the original post to include all code used. How would you suggest I proceed in rectifying my screw up?
Code tags? The </> icon.
I've added the tags now. Sorry about that, I'm rather new to this.
Any suggestions?
Use CTRL T to format your sketch.
There are lots of examples of timing with millis().
Here is one that should give you some ideas:
//Blink without Delay skeleton
//4 examples demonstrated
//LED wiring options
//Depending which way your LEDs are wired, uncomment the next line.
//#define PlusEqualsON
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON  HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON  LOW
#define ledOFF HIGH
#endif
//switch wiring options
//Depending which way your switches are wired, uncomment the next line.
#define PushEqualsLOW
#ifdef PushEqualsLOW
//pushing the switch makes pin LOW
#define Pushed   LOW
#define Released HIGH
#else
//pushing the switch makes pin HIGH
#define Pushed   HIGH
#define Released LOW
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL;     //100ms
unsigned long ledOnTime      = 5*1000UL;  //5 seconds
byte laststartSwitchState    = HIGH;
byte buttonState             = HIGH;
byte counter                 = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch  = 3; //pushed = LOW
  digitalWrite(13,ledOFF);
  pinMode(13, OUTPUT);
  digitalWrite(12,ledOFF);
  pinMode(12, OUTPUT);
  digitalWrite(11,ledOFF);
  pinMode(11, OUTPUT);
  digitalWrite(10,ledOFF);
  pinMode(10, OUTPUT);
  pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
  pinMode(testSwitch,  INPUT_PULLUP); //pushed = LOW
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //save the current time
  currentMillis = millis();
  //************************************* E x a m p l e  1
  //toggle pin 13 every 200mS
  //has 200ms or more gone by?
  if (currentMillis - pin13Millis >= 200UL)
    //code here runs every 200ms
    //get ready for next iteration
    pin13Millis = pin13Millis + 200UL;
    //toggle pin 13
    digitalWrite(13,!digitalRead(13));
  //************************************* E x a m p l e  2
  //at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
  //could be used as a powerup reset signal
  if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
    //code here runs for 3 seconds after power up, then stops
    digitalWrite(12,ledON);
    //disable further pin 12 control
    flag12 = false;
  //************************************* E x a m p l e  3
  //if testSwitch is pushed and released
  //pin 11 LED goes ON for 5 seconds, then goes OFF
  buttonState = digitalRead(testSwitch);
  //are we are allowed to check the switch and is it pressed?
  if(flag11 == true && buttonState == Pushed)
    //enable timing of LED on pin 11
    flag11 = false; //false --> timing is enabled
    //turn LED ON
    digitalWrite(11,ledON);
    //record the time LED turned ON
    pin11Millis = currentMillis;
  //are we allowed and is it time to control pin 11
  if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
    //if enabled, code here runs after ledOnTime ms goes by
    //allow switch press detection again
    flag11 = true; //true --> switch monitoring is enabled
  //************************************* E x a m p l e  4
  //is it time to check the switches?
  //in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    //get ready for the next iteration
    SwitchMillis += debounceMillis;
    //go and check the switches
    checkSwitches();
  //put other non-blocking stuff here
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
  //re-usable for all the switches
  boolean thisState;
  //************************************* E x a m p l e  Push ON push OFF (toggle)
  //check if this switch has changed state
  thisState = digitalRead(startSwitch);
  if (thisState != laststartSwitchState)
    //update the switch state
    laststartSwitchState = thisState;
    //this switch position has changed so do some stuff
    //"HIGH condition code"
    //switch went from LOW to HIGH
    if(thisState == HIGH)
      //Do some HIGH switch stuff here
    //"LOW condition code"
    //switch went from HIGH to LOW
      //Do some LOW switch stuff here
      digitalWrite(10, !digitalRead(10));
      //print number of pushes
      counter++;
      Serial.println(counter);
  } //END of startSwitch code
  //similar code for other switches goes here
} //END of checkSwitches()
//                      E N D  O F  C O D E
Thanks.
Every time you use a define like unsigned long you create a new variable. So don't do it inside a function that requires you to know a previous value. Make these variables global by defining them outside any function.
Then set your previous millis variable on the event you want to start timing, do not set it again. Then compair the current time with the previous or start time.
Basically you timing logic is screwed. Try and just write down the steps you need to do. You need to identify two things, when the time period should start and when it should end. You might want to use Boolean variables to keep track of what stage you are at.
Thanks guys… but I went for the lazy option
I used the delay.h library I found online to have a non interupting delay.
If it’s of any interest the code is now as follows:
#include <Delay.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
MMA8452Q accel;
String strData ="";
NonBlockDelay d;
int ledstate = LOW;
Serial.begin(4800);
accel.init();
pinMode(7, OUTPUT);
accel.read();
defData();
if (d.Timeout()) {
digitalWrite(7, ledstate);
ledstate = ledstate == HIGH ? LOW : HIGH;
d.Delay(9000);}}
if (dataFile) {
dataFile.close();
}else{
void defData()  {
I would have taken the high road, but time is a rather critical factor. My original code to deploy the parachute used a bool variable to store the orientation of the board, unfortunately this didnt work during practical testing.
Thanks anyways gentlemen.
