please help with RTC clock programming
I am a little desperate about this. It is a water gage where I want to energize water, but for a very short time to avoid electrolysis and corrosion of the contacts in water. I just want my blue LED to flash as long as water is missing in my water bucket, in which I have 2 wire ends to energize the water. I skipped the setup section and only kept the essential portion.
:confused:
// water bucket level “electrolysis free” gage
if ( now.second() >= 00 && now.second() <= 30 ) // if time on RTC is 00 to 30 sec
delay(5);
analogWrite (A2, 1023); // feed current into transistor base to energize water in bucket
delay(5);
delay(5);
analogWrite (A2, 0); // don’t feed current into transistor base to energize water in bucket
delay(5);
if ( now.second() >= 05 && now.second() <= 25 ) // if time on RTC is 05 to 25 sec…
if (digitalRead( 7) == LOW) // … and if you read no current on pin 7
delay(5);
digitalWrite( 4 , HIGH ); // flash the blue LED
delay( 250 );
digitalWrite( 4 , LOW );
delay( 250 );
digitalWrite(4, LOW); // if it’s not 05 to 25 sec AND LOW on pin 7, set blue LED off
    analogWrite (A2, 1023);Err.
Where's the rest of the code? Where are the code tags?
  if ( now.second() >= 05why the fixation with octal?
