I Have mastered everything arduino except LCD . The only LCD's i can get going are the
number displays. I Want to print text, and i own almost 30 LCD/TFT's that I've brought off of
eBay for various prices and of various sizes over a couple of months. So i thought I'd start it simple,
if one of you pro dudes can do the following for me i would be forever in debt. In the photo i have
uploaded, is the first LCD that i got, so i guess it must be the most simple. All i want is for you to
tell me which wires go where, and some simple sample HELLO WORLD code.
But i don't understand the simple wiring, for instance, my TFT has four pins, "GND" which is obvious,
then VCC, which i assume is +voltage?(help). Then "SCL"and "SDA". In the code it often outlines CS
and DS as pins. Which ones are CS and DS? SCL or SDA?
I Have spent my day trying countless TFT codes, none work, i get a blank white screen,
sometimes it jitters if commands are being sent, otherwise it's useless. My TFT display is
labelled on the front 3552, on the back :
You'll get some confusing answers because you have given different details in different posts.
In your first post, you referenced this picture. It is a LCD 1602 display (maybe with an I2C back pack)
