Please help. Wrong output with DHT22
I use this code
dht.setup(35);
delay(dht.getMinimumSamplingPeriod());
float humidity = dht.getHumidity();
float temperature = dht.getTemperature();
lcd.setCursor(0, 0);
lcd.print(dht.getStatusString());
lcd.setCursor(0, 1);
lcd.print(temperature);
delay(5000);
but output is 2.0. when I adjust temp to 80, output is 3.0
From what I understand from the library code, the getTemperature() function returns a string, not a float.
Try:
lcd.print(dht.getTemperature());
dano57ca:
Try:
It cannot work.
It can work now. I changed the DHT library to use this GitHub - adafruit/DHT-sensor-library: Arduino library for DHT11, DHT22, etc Temperature & Humidity Sensors.
Thank you
