Hello all
How to connect RFID and GPRS module by using arduino? Need wiring diagram .please help
Welcome to the Forum. Please read the two posts at the top of this Forum by Nick Gammon on guidelines for posting here, especially the use of code tags ("</>") when posting source code files. Also, before posting the code, use Ctrl-T in the IDE to reformat the code in a standard format, which makes it easier for us to read.
Can you please read Sticky Topic How to use this forum - please read.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7
Give us more detail of the RFID and GPRS module you use.
Have you got them working independently ?
What devices are you using ?
uhf rfid reader and gprs module
tcspune:
How come you did not respond to Reply #1 ?
...R
tcspune:
Can you please provide links?
Robin2:
How come you did not respond to Reply #1 ?...R
I'm probably just stupid, but how does reply 1 help in connecting devices to an Arduino board? It mostly refers to posting code. How does posting code help if one does not know how to connect a device to an Arduino?
I agree that OP can be a bit clearer in the devices that he/she uses (links are useful) as I have no idea what he/she is talking about).
sterretje:
I would agree completely with you if your reply had included the information the OP requires.
As it did not I remain of the view that answers to the questions in Reply #1 will help us to help the OP. As a general rule it is easier to help if the OP shares all of his (or her) project information with the Forum. Without that it is very easy for both parties to misunderstand each other. If you doubt me I suggest you have a look at several of the Threads on the Forum that run past 3 pages.
...R
sterretje:
You too, need more info on the devices, that is part of the answers of the reply #1
BillHo:
That is just a one-liner at the bottom of your post It can easily be overlooked; I did miss it twice before I realised
Just to make sure: not trying to be nasty.
