Please HELP!
I’m trying to add a code to turn led1 off the only way I figure how to do it was to
make.
if (digitalRead(2) == HIGH){
digitalWrite(11, LOW);
but when I do this the led1 keep flashing at a very low density I need it to stop the flash
Thanks in advance.
    #include <Servo.h>
    class Flasher
      // Class Member Variables
      // These are initialized at startup
      int ledPin;      // the number of the LED pin
      long OnTime;     // milliseconds of on-time
      long OffTime;    // milliseconds of off-time
      // These maintain the current state
      int ledState;                 // ledState used to set the LED
      unsigned long previousMillis;   // will store last time LED was updated
      // Constructor - creates a Flasher
      // and initializes the member variables and state
      public:
      Flasher(int pin, long on, long off)
      ledPin = pin;
      pinMode(ledPin, OUTPUT);
      OnTime = on;
      OffTime = off;
      ledState = LOW;
      previousMillis = 0;
      void Update()
        // check to see if it's time to change the state of the LED
        if((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
          ledState = LOW;  // Turn it off
          previousMillis = currentMillis;  // Remember the time
          digitalWrite(ledPin, ledState);  // Update the actual LED
        else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
          ledState = HIGH;  // turn it on
    class Sweeper
      Servo servo;              // the servo
      int pos;              // current servo position
      int increment;        // increment to move for each interval
      int  updateInterval;      // interval between updates
      unsigned long lastUpdate; // last update of position
    public:
      Sweeper(int interval)
        updateInterval = interval;
        increment = 1;
      void Attach(int pin)
        servo.attach(pin);
      void Detach()
        servo.detach();
      void Update()
        if((millis() - lastUpdate) > updateInterval)  // time to update
          lastUpdate = millis();
          pos += increment;
          servo.write(pos);
          Serial.println(pos);
          if ((pos >= 180) || (pos <= 0)) // end of sweep
            // reverse direction
            increment = -increment;
    Flasher led1(11, 250, 250);
    Flasher led2(12, 500, 500);
    Flasher led3(13, 125, 125);
    Sweeper sweeper1(15);
    Sweeper sweeper2(25);
      sweeper1.Attach(9);
      sweeper2.Attach(10);
      sweeper1.Update();
      if(digitalRead(2) == HIGH){
       sweeper2.Update();
       led1.Update();
      led2.Update();
      led3.Update();
How is the switch wired?
!(http://<a target=)">
|500x281
Use INPUT_PULLUP on pin 2 to see what happens. Use diagonal pins on the switch.
Thanks for your help.
this is what I did and it is much better than before but I still see led1 flashing at very low density but much lower than before is almost unnoticeable
any ideas on how can I stop the flashing?
    #include <Servo.h>
    class Flasher
      public:
      ledPin = pin;
      OnTime = on;
      OffTime = off;
      ledState = LOW;
      previousMillis = 0;
      void Update()
    class Sweeper
    public:
        increment = 1;
        servo.attach(pin);
      void Detach()
        servo.detach();
      void Update()
          pos += increment;
          servo.write(pos);
      sweeper1.Attach(9);
      pinMode(2, INPUT_PULLUP);
      sweeper1.Update();
      else if (digitalRead(2) == LOW);
      led1.Update();
      led2.Update();
      led3.Update();
One thing to do is to stop diddling with the hardware in your constructors. The hardware is not ready to be diddled with when the constructors are called. Add a begin() method to each class, and diddle with the hardware in that method.
else if (digitalRead(2) == LOW) ; I don't think you want the ;
Where do you want the { } to go for the else if ?
else if (digitalRead(2) == LOW) {
You could leave the 'else if' just a 'else' .
EDIT: digitalWrite(11, LOW); this controls pin 11 And so does led1.Update(); Not wise ;)
