Please I need another similar component as BTS432E2
Pin1. GND logic gnd
Pin2. IN input, activates the power switch in case of logical high signal
Pin3. Vbb positive power voltage
Pin4. ST diagnostic feedback, low on failure
Pin5. OUT output to load
My BTS432E2 got damage and I was unable to get any replaceable one as exactly same component...... so I don't know if I can get a similar component with the same function for me to replace it.... Please list similar component that can be used to replace it... thank you
Lots on eBay and Amazon.
Posting a link to the Data Sheet would help all of us help you. I do not do well with word problems nor do many others. I am curious did you even try to find it. I entered just the BTS4232E2 in Google and got both data and sources on the first page. A bit of advice that is a very rugged part, I am surprised you managed to damage it unless you lost ground. There are several variations of that part and the E2 will tell you what they are. Mainly it is in how the diagnostic feedback operates and the chip fault protection.
Yes have the datasheet but to get another similar component with the same function is my problem ... thank you
Yes but it will take about 3weeks to arrive at my place and it kind of urgent and I was unable to get it here in the market so I need another similar type that can replace it
If I can get names of a similar component to this one...I can check here aty place if I can get it
May be it will be useful for you
https://eu.mouser.com/c/semiconductors/switch-ics/power-switch-ics-power-distribution/
You may be able to kluge in a BTS660 or similar high side driver to get some operation but the status will not be there and the protection but it could get you by for a demo. Without the circuit etc I can only take a guess.
Thanks
What is your load?
Can you use a P-CH MOSFET and NPN BJT to get you out of trouble?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Thank you @TomGeorge I will check and see
