my motor only have 2 wire…drawing have 3 wire…how i must assemble it??
Your question does not make sense.
The thing in the drawing is a servo which is why it has 3 wires - Power, GND and signal.
You cannot simply substitute a DC motor without also changing the code.
And you CANNOT connect a DC motor directly to Arduino I/O pins. You need some sort of motor driver, or a transistor between the Arduino and the motor.
...R
