please need help with VS1053b
Hi
I’ve been trying to get the ultrasonic sensor to work with the VS1053b
what I want is that controlling the music (on& off) depending on the distance measured
by the ultrasonic sensor!
I am using an arduino uno + music shield VS1053b
this is the code i tried , but not have worked!
i wonder if anyone can direct me as to where i am going wrong.
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define BREAKOUT_RESET 9
#define BREAKOUT_CS 10
#define BREAKOUT_DCS 8
#define SHIELD_RESET -1
#define SHIELD_CS 7
#define SHIELD_DCS 6
#define CARDCS 4
#define DREQ 3
Adafruit_VS1053_FilePlayer musicPlayer =
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
int echoPin=12;
int trigPin=13;
Serial.println(“Adafruit VS1053 Simple Test”);
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F(“Couldn’t find VS1053, do you have the right pins defined?”));
while (1);
Serial.println(F(“VS1053 found”));
SD.begin(CARDCS);
musicPlayer.setVolume(20,20);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
float duration, distance;
digitalWrite(trigPin, HIGH);
delay(10);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = duration/58;
Serial.print(distance);
Serial.println(“cm”);
if( 5 < distance || distance < 20 )
musicPlayer.playFullFile(“track001.mp3”);
musicPlayer.pausePlaying(true);
delay(100);
You haven’t posted the code correctly. Please read this:-
How to use this forum
You have also not said what the code actually does.
Have you got each part of the hardware working separately?
