Please please lend the power.
I want to use LEDLevelmeter using supersonic wave distance sensor HC-SR04 while moving Servo.
When it is this sketch, I do not operate.
I think, but do not understand that it is how to put in Servo.
Please tell.
#include <Servo.h>
Servo A;
int tonePin = 4; //Tone - Red Jumper
int trigPin = 9; //Trig - violet Jumper
int echoPin = 10; //Echo - yellow Jumper
int clockPin = 11; //IC Pin 11 - white Jumper
int latchPin = 12; //IC Pin 12 - Blue Jumper
int dataPin = 13; //IC Pin 14 - Green Jumper
int pos = 0;
byte possible_patterns[9] = {
B00000000,
B00000001,
B00000011,
B00000111,
B00001111,
B00011111,
B00111111,
B01111111,
B11111111,
int proximity = 0;
int duration;
int distance;
//Serial Port
Serial.begin (9600);
A.attach(2);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(tonePin, OUTPUT);
digitalWrite(latchPin, LOW);
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) / 29.1;
/if (distance >= 45 || distance <= 0){
Serial.println(“Out of range”);
else {
Serial.print(distance);
Serial.println(" cm");
proximity = map(distance, 0, 45, 8, 0);
//Serial.println(proximity);
if (proximity <= 0) {
proximity = 0;
else if (proximity >= 3 && proximity <= 4) {
tone(tonePin, 200000, 200);
else if (proximity >= 5 && proximity <= 6) {
tone(tonePin, 5000, 200);
else if (proximity >= 7 && proximity <= 8) {
tone(tonePin, 1000, 200);
shiftOut(dataPin, clockPin, MSBFIRST, possible_patterns[proximity]);
digitalWrite(latchPin, HIGH);
delay(600);
noTone(tonePin);
for ( pos = 0; pos < 180; pos += 1 ) {
A.write( pos );
delay( 15 );
for ( pos = 180; pos > 0; pos -= 1 ) {
A.write( pos );
delay( 15 );
That's because there is a smiley in your code...
Use the code tags... Then we can see..
Seems to me we saw this code before.
@kili: Please read the post by Nick Gammon at the top of this Forum on the proper way to pose a question here.
And may the Force be with you.
I do not understand it at all.
It does not rise in the part of ('д`).
It is beginner Closed to the Public
Welcome to the Forum
http://forum.arduino.cc/index.php/topic,148850.0.html
then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What is your native language?
Thanks… Tom… :slight_smile:
