PLEASE PLEASE PLEASE HELP!!! SERVO PROBLEMS!!!
I have tried, through my WHOLE SUNDAY to get this code:
DO
  IF PULSES < 600 THEN
    GOTO increment
  ELSEIF PULSES > 1150 THEN
    GOTO decrement
  ENDIF
increment:
PULSES = 600
DO
  PULSES = PULSES + 25
  PULSOUT 15, PULSES
  PAUSE 20
LOOP UNTIL PULSES > 1150
RETURN
decrement:
PULSES = 1150
DO
  PULSES = PULSES - 25
  PULSOUT 15, PULSES
  PAUSE 20
LOOP UNTIL PULSES < 600
RETURN
LOOP
…And trun it into Arduino code. So far, I have been unsuccessful, and I already blew out a nice Hitec micro servo in the process. Does anyone in these forums have experience with PBASIC code? I need to get the arduino code to do what the PBASIC code is written to do. If not, I can explain how the PBASIC code works. By now though, I am pretty frustrated with my servo program. Can anyone help me??!! :’(
Here’s my (unsuccessful) Arduino code (ignore the commented out parts):
int servoPin = 3;
int irPin = 0;
int val = 0;
int pulses;
        pinMode(servoPin, OUTPUT);
  if(pulses < 1250)
    increment();
  else if(pulses > 2225)
    decrement();
  //val = analogRead(irPin);
  //delay(5);
  //Serial.println("PULSE");
  //Serial.println(pulses);
  //delay(5);
  //Serial.println("IR");
  //delay(5);
  //Serial.println(val);
void increment()
  //pulses = 1250;
  while(pulses > 1252)
    pulses = pulses + 15;
    digitalWrite(servoPin, HIGH);
    delay(pulses);
    digitalWrite(servoPin, LOW);
    delay(20);
    return;
void decrement()
  //pulses = 2225;
    pulses = pulses - 15;
    delay(pulses);
    delay(20);
    return;
delay(n) delays n milliseconds. In my servo code, I use delayMicroseconds(). Maybe you’re using the wrong function and your units are off?
-j
delay(n) delays n milliseconds. Maybe you’re using the wrong function and your units are off?
-j
kg4wsv is right, the pulse width should be in microseconds in your code. But the delay(20) after the pulse is correct, that should remain at 20 milliseconds.
delayMicroseconds(pulses); // this needs to be in microseconds
delay(20); // this delay of 20 milliseconds is correct
I figured it out. Thanks, though. I need to start a new thread, though. thread closed
Here’s the code (with other stuff in it that I need help with. I’m going to address it in another thread).
int servoPin = 3;
int irPin = 0;
int val = 0;
int pulses;
  if(pulses >= 2300)
    {  pulses = 2300;
      do
        pulses = pulses - 50;
        delay(20);
        readir();
      } while(pulses >= 1300);
  else if(pulses <= 1300)
    {  pulses = 1300;
      do
        pulses = pulses + 50;
        delay(20);
        readir();
      } while(pulses <= 2300);
void readir()
    //delay(5);
    delay(5);
    delay(5);
    delay(5);
