Please slove this error
Arduino: 1.8.15 (Windows 7), Board: "Generic ESP8266 Module, 80 MHz, 40MHz, DOUT, 115200, 512K (64K SPIFFS), nodemcu, Disabled, None"
C:\Users\home\Documents\Arduino\node\node.ino: In function 'void loop()':
node:58:30: error: expected primary-expression before 'available'
WiFiClient client = Server available();
exit status 1
option enabled in File -> Preferences.
A dot?
Server.available();
I suspect you need to check your cut & paste.
The code snippet you posted makes no sense
@sahil01, your topic has been moved to a more suitable location on the forum.
Nobody will be able to solve your problem if you don't post your code.
Please spend some time reading How to get the best out of this forum and next post your code using code tags as described in the link.
dot - not only.
i will send a code please correct it please #include <Blynk.h>
#include<ESP8266WiFi.h>
const char* ssid = "sahil"; // SSID i.e. Service Set Identifier is the name of your WIFI
const char* password = "12345678"; // Your Wifi password, in case you have open network comment the whole statement.
int R1 = 1; // GPIO13 or for NodeMCU you can directly write D7
int R2 = 2;
int R3 = 3;
int R4 = 4;
WiFiClient client;
delay(10);
pinMode(R1, OUTPUT);
pinMode(R2, OUTPUT);
pinMode(R3, OUTPUT);
pinMode(R4, OUTPUT);
digitalWrite(R1, LOW);
digitalWrite(R2, LOW);
digitalWrite(R3, LOW);
digitalWrite(R4, LOW);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.println("/");
// Check if a client has connected
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while (!client.available()) {
delay(1);
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
if (request.indexOf("/Relay1On") != -1) {
digitalWrite(R1, HIGH);
client.println("Content-Type: text/html");
client.println("");
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("Relay 1 is ON");
client.println("</html>");
client.stop();
delay(1);
if (request.indexOf("/Relay1Off") != -1) {
client.println("");
client.println("Relay 1 is OFF");
client.stop();
delay(1);
if (request.indexOf("/Relay2On") != -1) {
digitalWrite(R2, HIGH);
client.println("");
client.println("Relay 2 is ON");
client.stop();
delay(1);
if (request.indexOf("/Relay2Off") != -1) {
client.println("");
client.println("Relay 2 is OFF");
client.stop();
delay(1);
if (request.indexOf("/Relay3On") != -1) {
digitalWrite(R3, HIGH);
client.println("");
client.println("Relay 3 is ON");
client.stop();
delay(1);
if (request.indexOf("/Relay3Off") != -1) {
client.println("");
client.println("Relay 3 is OFF");
client.stop();
delay(1);
if (request.indexOf("/Relay4On") != -1) {
digitalWrite(R4, HIGH);
client.println("");
client.println("Relay 4 is ON");
client.stop();
delay(1);
if (request.indexOf("/Relay4Off") != -1) {
client.println("");
client.println("Relay 4 is OFF");
client.stop();
delay(1);
#include <Blynk.h>
int R2 = 2;
int R3 = 3;
int R4 = 4;
WiFiClient client;
delay(10);
Serial.print(".");
Serial.println("");
// Start the server
if (!client) {
return;
delay(1);
client.flush();
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
please correct the code and send to me i am your student
Again, please read the link that I gave you.
Next edit your post, select all code and click </> above the editor text box and save your post.
#include <Blynk.h>
int R2 = 2;
int R3 = 3;
int R4 = 4;
  WiFiClient client;
  delay(10);
  Serial.print(".");
Serial.println("");
// Start the server
  if (!client)
    return;
    delay(1);
  client.flush();
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
    client.println("");
    client.stop();
    delay(1);
:pray: you are great please correct the code
#include <Blynk.h>
int R2 = 2;
int R3 = 3;
int R4 = 4;
WiFiClient client;
delay(10);
Serial.print(".");
Serial.println("");
// Start the server
if (!client) {
return;
delay(1);
client.flush();
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
client.println("");
client.stop();
delay(1);
I've merged your cross-posts @sahil01 .
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide you will find at the top of every forum category. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
the error: client = Server available();
I suggest you use this code to set up the WiFi communication
  Serial.begin(115200);         // Start the Serial communication to send messages to the computer
  delay(10);
  Serial.println('\n');
  WiFi.begin(ssid, password);             // Connect to the network
  Serial.print(ssid); Serial.println(" ...");
  int i = 0;
  while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
    Serial.print(++i); Serial.print(' ');
  Serial.println("Connection established!");
  Serial.print("IP address:\t");
  Serial.println(WiFi.localIP());         // Send the IP address of the ESP8266 to the computer
This part of your setup is all wrong
