Please solve this error: 'Need to declare TCCR1A in this scope'. on Arduino R4 minima
#define BAUD 115200
class PID
private:
double _prev_time, _now, _dt;
double _prev_error, _error;
double _Kp, _Ki, _Kd;
int _direction;
double _setpoint;
double _integral;
double _output, _prev_output;
public:
PID()
_prev_time=_now=micros()*1e-6;
_prev_error=_error=0.0;
_dt=1e9;
_setpoint=0.0;
_integral=0.0;
_Kp=_Ki=_Kd=0.0;
_output=0.0;
_direction=1.0;
void reverse()
int _direction=-1;
void setPoint(double setpoint)
_setpoint=setpoint;
void setTunings(double Kp, double Ki, double Kd)
if(Ki!=0.0)
_integral*=_Ki / Ki;
_Kp=Kp;
_Ki=Ki;
_Kd=Kd;
double Compute(double input)
_now=micros() 1e-6;
if(_now>_prev_time)
_dt=_now-_prev_time;
_error=input-_setpoint;
_integral+=_error
_dt;
_output= _Kp*_error+_Ki*_integral+_Kd*(_error-_prev_error)/_dt;
_prev_time=_now;
_prev_error=_error;
_prev_output=_output;
return (unsigned int) (_output*_direction)&0x00000000ff;
double getIntegral()
return _integral;
double Setpoint=500, Input, Output, Error;
double Kp_f = 0.4;
double Ki_f = 8;
double Kd_f = 0.0;
double Kp = 1;
double Ki = 20;
double Kd = 0.002;
unsigned long ii = 0;
PID myPID;
pinMode(6, OUTPUT);
TCCR1A = 0b00000001;
TCCR1B = 0b00001001;
pinMode (A0, INPUT);
Serial.begin (BAUD);
myPID.setTunings (Kp, Ki, Kd);
myPID.setPoint (Setpoint);
myPID.reverse ();
Input=analogRead(A0); // put your main code here, to run repeatedly:
Error = Input-Setpoint;
if (abs(Error)<3)
myPID.setTunings (Kp_f,Ki_f,Kd_f);
else if(abs(Error)>5)
myPID.setTunings(Kp,Ki,Kd);
Output = myPID.Compute(Input);
analogWrite(6, Output);
if(ii++%100==0)
Serial.print(Input);
Serial.print(',');
Serial.print(Output);
Serial.print(',');
Serial.print(abs(Error)/Setpoint*100);
Serial.print(',');
Serial.print(myPID.getIntegral());
Timer and Counter Control Registers are used in the AVR microcontrollers used by many Arduinos, including the Arduino Uno R3.
However the Arduino Uno R4 uses a Renesas microcontroller that does not have these registers.
You will need to alter the lines
to something else, sorry I can't tell you what.
Other changes may be necessary .
The document Renesas RA4M1 Group - Users Manual - Hardware will give you more information.
Porting low level register access from one architecture to another is often not simple.
I would suggest trying to find sample code that runs on your board.
Failing that, get a board that supports the software you want to use.
I think the lines
set the PWM frequency, see ISR timer interrupt combined with fast PWM frequency - #4 by ttijass
bob cousins,
Nicely said. :+1:
