Pleses help about arduino wire.h
I'm new to arduino. I had found an interesting project to work on with, but unfortunately I'm held up at compilation error.
Here is my code:
#include "MPU6050.h"
#include<Wire.h>
const uint8_t MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
uint8_t minVal=265;
uint8_t maxVal=402;
double x;
double y;
double z;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
uint8_t xAng = map(AcX,minVal,maxVal,-90,90);
uint8_t yAng = map(AcY,minVal,maxVal,-90,90);
uint8_t zAng = map(AcZ,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print("AngleX= ");
Serial.println(x);
Serial.print("AngleY= ");
Serial.println(y);
Serial.print("AngleZ= ");
Serial.println(z);
Serial.println("-----------------------------------------");
delay(400);
here is the error log
In file included from c:\Users\cmt33\Documents\Arduino\libraries\MPU6050\src/I2Cdev.h:88,
from c:\Users\cmt33\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:40,
from C:\Users\cmt33\Documents\Arduino\WIFI\WIFI.ino:1:
C:\Users\cmt33\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\Wire\src/Wire.h: In function 'void loop()':
C:\Users\cmt33\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\Wire\src/Wire.h:126:13: note: candidate 1: 'uint8_t TwoWire::requestFrom(int, int, int)'
uint8_t requestFrom(int address, int size, int sendStop);
C:\Users\cmt33\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\Wire\src/Wire.h:122:12: note: candidate 2: 'size_t TwoWire::requestFrom(uint8_t, size_t, bool)'
size_t requestFrom(uint8_t address, size_t len, bool stopBit);
C:\Users\cmt33\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\Wire\src/Wire.h:120:13: note: candidate 2: 'uint8_t TwoWire::requestFrom(uint16_t, uint8_t, bool)'
uint8_t requestFrom(uint16_t address, uint8_t size, bool sendStop);
C:\Users\cmt33\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\Wire\src/Wire.h:119:12: note: candidate 2: 'size_t TwoWire::requestFrom(uint16_t, size_t, bool)'
size_t requestFrom(uint16_t address, size_t size, bool sendStop);
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Do only answer one thing per posting?
best regards Stefan
the posted code compiles without any errors for me with the IDE configured for an Uno
The logfile talks about ESP32
what exact type of microcontroller are you using?
did you install the board-package for this type of microcontroller?
best regards Stefan
i am using wemos D1 R32
board-package is ESP32 2.0.7
Do you answer only one question per Posting?
best regards Stefan
A couple of problems. First, these numbers are too large for an 8-bit unsigned integer:
uint8_t minVal = 265;
uint8_t maxVal = 402;
Second, the line the compiler does not like, is caused by the arguments for the function call not fitting the exact argument types for any of the overloads of the function. Your arguments are (uint8_t, int, bool), cast the 2nd argument to (size_t), or the 1st and 3rd to (int), and the code will compile.
  Wire.requestFrom(MPU_addr, 14, true);
If you have the compiler set to show all warnings, you will get warning messages on an UNO. The ESP32 boards package is not as lenient with converting errors to warnings in the compiler options, so will show an error.
guess i copied the wrong file because i get an warning for above, as well as many others
the following compiled for both UNO and esp32
also corrected warnings about "#endif;" in MPU6050.cpp
#include<Wire.h>
uint16_t minVal=265;
uint16_t maxVal=402;
double x;
double y;
double z;
void setup (){
    Wire.begin ();
    Wire.beginTransmission (MPU_addr);
    Wire.write (0x6B);
    Wire.write (0);
    Wire.endTransmission (true);
    Serial.begin (9600);
void loop (){
    Wire.write (0x3B);
    Wire.endTransmission (false);
#if 0
    Wire.requestFrom (MPU_addr, (byte)14, (bool)true);
#else
    Wire.requestFrom (MPU_addr, (byte)14);
#endif
    AcX=Wire.read ()<<8|Wire.read ();
    AcY=Wire.read ()<<8|Wire.read ();
    AcZ=Wire.read ()<<8|Wire.read ();
    uint8_t xAng = map (AcX,minVal,maxVal,-90,90);
    uint8_t yAng = map (AcY,minVal,maxVal,-90,90);
    uint8_t zAng = map (AcZ,minVal,maxVal,-90,90);
    x= RAD_TO_DEG * (atan2 (-yAng, -zAng)+PI);
    y= RAD_TO_DEG * (atan2 (-xAng, -zAng)+PI);
    z= RAD_TO_DEG * (atan2 (-yAng, -xAng)+PI);
    Serial.print ("AngleX= ");
    Serial.println (x);
    Serial.print ("AngleY= ");
    Serial.println (y);
    Serial.print ("AngleZ= ");
    Serial.println (z);
    Serial.println ("-----------------------------------------");
    delay (400);
