Plot line graph on TFT screen
Hi, I am currently doing my fyp project that requires me to plot a line graph on my TFT screen, which has an ILI9341 controller drive. I am using the 6-axis IMU sensor and Force-sensitive resistive sensor, and I need to plot a line graph based on the input data from these sensors.
TFT screen: 2.8 TFT Touch Shield for Arduino with Resistive Touch Screen : ID 1651 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits
IMU: https://www.makersupplies.sg/products/mpu-6050-six-axis-unsoldered?variant=17216531595310&currency=SGD&utm_campaign=gs-2019-09-08&utm_source=google&utm_medium=smart_campaign&gclid=Cj0KCQiAkKnyBRDwARIsALtxe7ixvjAhjgECytEEYCllCEjaHmfApNpAfjtmBiWY3eGlFcWBbtNQpx8aAtsVEALw_wcB
Force-sensitive resistive sensor: https://www.sgbotic.com/index.php?dispatch=products.view&product_id=1085
Currently, I have successfully programmed both IMU and force-sensitive resistive sensors, and I'm stuck at plotting the graph. (I have attached the code for IMU + force-sensitive resistive sensor)
#include "Wire.h"
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#define TFT_DC 9
#define TFT_CS 10
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
const int MPU = 0x68; // MPU6050 I2C address
float GyroX, GyroY, GyroZ;
float GyroErrorX, GyroErrorY, GyroErrorZ;
float elapsedTime, currentTime, previousTime;
int c = 0;
int Resultant;
int fsrPin = 8;     // the FSR and 10K pulldown are connected to a0
int fsrReading;     // the analog reading from the FSR resistor divider
int fsrVoltage;     // the analog reading converted to voltage
unsigned long fsrResistance;  // The voltage converted to resistance, can be very big so make "long"
unsigned long fsrConductance;
long fsrForce;       // Finally, the resistance converted to force
  tft.begin();
  tft.fillScreen(ILI9341_BLACK);
  tft.setRotation(4);
  //IMU
  Wire.begin();                      // Initialize comunication
  Wire.beginTransmission(MPU);       // Start communication with MPU6050 // MPU=0x68
  Wire.write(0x6B);                  // Talk to the register 6B
  Wire.write(0x00);                  // Make reset - place a 0 into the 6B register
  Wire.endTransmission(true);        //end the transmission
  //calculate_IMU_error();
  pinMode(40, OUTPUT); //LED
  tft.setTextColor(ILI9341_WHITE,ILI9341_BLACK);  tft.setTextSize(1);
  tft.setCursor(0,5);
  tft.print("Angular Velocity (deg/sec): ");
  tft.setCursor(0,18);
  tft.print("Force in Forearm(N): ");
  delay(20);
 digitalWrite(40, HIGH);
 // === Read gyroscope data === //
  previousTime = currentTime;        // Previous time is stored before the actual time read
  currentTime = millis();            // Current time actual time read
  elapsedTime = (currentTime - previousTime) / 1000; // Divide by 1000 to get seconds
  Wire.write(0x43); // Gyro data first register address 0x43
  Wire.endTransmission(false);
  Wire.requestFrom(MPU, 6, true); // Read 4 registers total, each axis value is stored in 2 registers
  GyroX = (Wire.read() << 8 | Wire.read()) / 131.0; // For a 250deg/s range we have to divide first the raw value by 131.0, according to the datasheet
  GyroY = (Wire.read() << 8 | Wire.read()) / 131.0;
  GyroZ = (Wire.read() << 8 | Wire.read()) / 131.0;
  // Correct the outputs with the calculated error values
  GyroX = GyroX + 0.56; // GyroErrorX ~(-0.56)
  GyroY = GyroY - 2; // GyroErrorY ~(2)
  GyroZ = GyroZ + 0.79; // GyroErrorZ ~ (-0.8)
  //Average angular speed
  int Resultant;
  int squareRAW;
  squareRAW = sq(GyroX)+sq(GyroY);
  Resultant = sqrt(squareRAW); //resultant angualar speed of x-axis and y-axis
  //tft.setTextColor(ILI9341_WHITE,ILI9341_BLACK);  tft.setTextSize(1);
  //tft.print("Angular Velocity = ");
  tft.setCursor(165,5);
  tft.print(Resultant);
  //tft.println(" (deg/sec) ");
  Serial.print("Angular Velocity = ");
  Serial.print(Resultant);
  Serial.println(" (deg/sec) ");
  // === Read force sensitive resistor data === //
  fsrReading = analogRead(fsrPin);
  //Serial.print("Analog reading = ");
  //Serial.println(fsrReading);
   // analog voltage reading ranges from about 0 to 1023 which maps to 0V to 5V (= 5000mV)
  fsrVoltage = map(fsrReading, 0, 1023, 0, 5000);
  //Serial.print("Voltage reading in mV = ");
  //Serial.println(fsrVoltage);
  if (fsrVoltage == 0)
    tft.setCursor(130,18);
    tft.print("0");
    Serial.println("Force in Forearm = 0 N");
    // The voltage = Vcc * R / (R + FSR) where R = 10K and Vcc = 5V
    // so FSR = ((Vcc - V) * R) / V
    fsrResistance = 5000 - fsrVoltage;     // fsrVoltage is in millivolts so 5V = 5000mV
    fsrResistance *= 10000;                // 10K resistor
    fsrResistance /= fsrVoltage;
    //Serial.print("FSR resistance in ohms = ");
    //Serial.println(fsrResistance);
    fsrConductance = 1000000;           // we measure in micromhos so
    fsrConductance /= fsrResistance;
    //Serial.print("Conductance in microMhos: ");
    //Serial.println(fsrConductance);
    // Use the two FSR guide graphs to approximate the force
      if (fsrConductance <= 1000) {
      fsrForce = fsrConductance / 80;
      tft.print(fsrForce);
      //tft.println(" N");
      Serial.print("Force in Forearm: ");
      Serial.print(fsrForce);
      Serial.println(" N");
      fsrForce = fsrConductance - 1000;
      fsrForce /= 30;
  Serial.println("--------------------");
I have added the following code to plot the graph, but I'm not really sure how the library works for TFT screen in order for me to plot a proper graph.
void graph (void){
  int y1, y2, z1, z2;
  for (int x=1; x<319; x++){
    y2 = map(Resultant, 0, 1023, 0, 240);
    z2 = map(fsrForce, 0, 1023, 0, 240);
    tft.drawLine(x,y1,x+1,y2,ILI9341_BLUE);
    tft.drawLine(x,y1,x+1,y2,ILI9341_RED);
    y1 = y2;
    z1 = z2;
I would really appreciate if someone could explain to me how I can move on with the plotting of the line graph for my project. Thank you!!!
The best approach is to carefully look at the library documentation and try out the examples.
Then, write a simple program that does nothing more that plot a box on the TFT screen.
When you get that working, you will be well prepared to add code as required to the larger program.
