Plotting Arduino Data in Matlab
i want to generate sine wave in arduino using mathematical sine function and then plot it in MATLAB.
i took help from this link
then i tried my own codes
for arduino
{ Serial.begin(115200); }
unsigned a;
a= millis()/10;
float b;
b=sin(a);
Serial.println(b);
delay(1);
For MATLAB i used
s=serial('COM3','BaudRate',115200);
fopen(s)
x=1:100;
n=1;
while n==1
   for i=1:length(x)
       tmp=fscanf(s,'%d');
       if length(tmp)>1
          continue;
       end
       y(i)=tmp;
   end
     plot(y)
   drawnow
   end
fclose(s)
But i got two problems
  1. MATLAB errors :Series of Warning: Unsuccessful read: Matching failure in format.
    then in the end
    In an assignment A(I) = B, the number of elements in B and I must be the same.
Error in experiemt (line 11)
y(i)=tmp;
  1. The plot i got i got had values of sine as 0, -1 or 1 nothing else
If someone could help
Thanks
layout is important for the readability of code.
removed some code not needed.
  unsigned long a = millis()/10;
  float b = sin(a);
  Serial.println(b);
The problem is on the receiving end as you need to read digits until you get the CR LF from the arduino.
Now the matlab code just tries to parse the digits that are in the receive buffer, which may not be the complete number. You must also skip the CRLF chars of course...
Fix that and your code will work.
I dnt know CR LF
i shud first look at wat it is, then wud try to figure it again.
thnx
Does it work this way?
CR= start bit
LF= end bit
nd how to i synchronize the receiver (MATLAB) with sender (arduino)
If u modify my code it wud be really appreciable.
THANKS
How to tell MATLAB its the strt of data nd its the end
robtillaart if u can answer this
CRLF = Carriage Return and Line Feed
these are resp. char(13) and char(10)
under windows when you press or these two ASCII codes are used.
You can use them to determine the end of a line.
