pls check wether my code ha any problems
#include <SD.h>
#include <TMRpcm.h>
#include <SPI.h>
#define SD_ChipSelectPin 4
const int trigPin = A0;
const int echoPin = A1;
const int speakerPin = 9;
long duration;
int distance;
TMRpcm tmrpcm;
void setup(){
tmrpcm.speakerPin = 9;
tmrpcm.setVolume(6);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
void loop(){
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration*0.034/2;
if (distance>300){
tmrpcm.play(“1.wav”);}
if (distance<300 && distance>200){
tmrpcm.play(“2.wav”);}
if (distance<200 && distance>100){
tmrpcm.play(“4.wav”);}
if (distance<100 && distance>50){
tmrpcm.play(“6.wav”);}
if (distance<50){
tmrpcm.play(“7.wav”);}
this is my code pls tell me if it can work
if i compile it it says exit status 1
please do hep me i have t submit my project in school within 2 days
It says a whole lot more than that.
Please post all of it.
Please remember to use code tags when posting code
that is all of my code
what else should i post??
tell me i will do it
n pls help
Please post ALL the error message - you may need to scroll up to see it all, or use the "copy error message" control, and post it here.
Arduino: 1.6.9 (Windows 10), Board: “Arduino Nano, ATmega328”
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino:2:20: fatal error: TMRpcm.h: No such file or directory
#include <TMRpcm.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Nano.
“Show verbose output during compilation”
option enabled in File → Preferences.
Seems you didn’t (correctly) install the TMRpcm library?
pls tell me how to do it
raghav007:
First I guess is to go Sketch > Include library > Manage libraires in the IDE and see if it’s there. If it is, install it.
If not, you’ll need to find it then copy it to a folder and use the Sketch > Include library > Install .zip library.
By the way, and besides that lack-of-library-problem, when you use SPI you're supposed to set the Arduino's own Slave Select pin (10 on an Uno, 53 on Mega) to be an output. If you don't, the pin which by default is an input may be made low by mistake, and that inadvertently makes the Arduino a slave. You don't want that, as the reference says:
All AVR based boards have an SS pin that is useful when they act as a slave controlled by an external master. Since this library supports only master mode, this pin should be set always as OUTPUT otherwise the SPI interface could be put automatically into slave mode by hardware, rendering the library inoperative.
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino: In function ‘void loop()’:
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino:39:20: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino:42:20: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino:45:20: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino:48:20: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
C:\Users\Admin\Music\raghav\blind goggles\goggles\goggles.ino:51:20: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
i am getting this now
You'll notice that the word "error" didn't appear in your last post.
