PLS HELP FOR DIY WATER LEVEL SENSOR CODE
does anyone how to code a diy water level using only wires
i tried using this code but it doesnt seem to work
int a=0;
int b=0;
int c=0;
void setup(){
pinMode(A4,INPUT);
pinMode(A3,INPUT);
pinMode(A2,INPUT);
{ int r=digitalRead(A4);
int s=digitalRead(A3);
int t=digitalRead(A2);
if(r==HIGH && s==LOW && t==LOW)
{ if(a==0)
Serial.print("Level 1 ");
a++; b=0; c=0;
if(r==HIGH && s==HIGH && t==LOW)
{ if(b==0)
Serial.print("Water at Level 2 ");
//the message you want to send
b++; a=0; c=0;
if(r==HIGH && s==HIGH && t==HIGH) { if(c==0)
Serial.print("Water at Level 3 ");
c++; b=0; a=0; }
{ Serial.print("Circuit Not Connected");
any help will be much apprecieated
Hello
Welcome to the Arduino fora.
Before you do anything else please take a moment to read General guidance
And
How to use this forum
Especially item #7 on posting code.
Thank you
You didn’t say what “working” means.
The code does something, so describe that.
Don’t use single letters as variable names, and try to use a consistent indentation style.
it just repeatedly spams "circuit not connected" in the serial monitor
And is the unspecified circuit connected?
yes
Ok.
I guess we’ll just have to take your word that the still unspecified circuit is connected.
Good luck.
Please post a schematic (hand drawn and photographed is OK) of your project
Here is your code Auto Formatted in the IDE
int a = 0;
int b = 0;
int c = 0;
  pinMode(A4, INPUT);
  pinMode(A3, INPUT);
  pinMode(A2, INPUT);
  int r = digitalRead(A4);
  int s = digitalRead(A3);
  int t = digitalRead(A2);
  if (r == HIGH && s == LOW && t == LOW)
    if (a == 0)
    a++;
    b = 0;
    c = 0;
  if (r == HIGH && s == HIGH && t == LOW)
    if (b == 0)
    b++;
    a = 0;
    c = 0;
  if (r == HIGH && s == HIGH && t == HIGH)
    if (c == 0)
    c++;
    b = 0;
    a = 0;
The indentation makes it much clearer which code is dependant on the tests and which will be executed unconditionally.
As a general rule it is best to enclose conditional code blocks in { and } even if there is only one conditional statement. A useful technique is to print the values being tested immediately before the test to see which parts of the code are being executed and the value of pertinent variables
