pls! help me Arduino code
I have a problem in the process of writing code is
//Transfer code from Data_one to LockCode
//Transfer code from Data_one to UnLockCode
// Compare LockCode & UnLock Code (if)
// Match (Unlock)- Send signal to hardware
// Not match (Ignore - Warning)
I don know the command to write a code. Pls help me thx
additional
I 'm trying to do the code on the lock and unlock .
By entering the code number 4 number.
Followed by # and lock
And put it once again
Followed by the * key to unlock.
#include <Keypad.h>
#include <LiquidCrystal.h>
#define Password_Lenght 4 //
LiquidCrystal LCD(A0, A1, A2, A3, A4, A5);
char Data_one[Password_Lenght]; //4 int
byte maxPasswordLength = 4;
byte currentPasswordLength = 0;
byte data_count_one = 0,data_count_two = 0, master_count = 0;
boolean Pass_is_good1 = false;
boolean Pass_is_good2 = false;
boolean Pass_is_good3 = false;
boolean Pass_is_good4 = false;
char customKey_one,customKey_two;
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {10, 9, 8, 7};
byte colPins[COLS] = {13, 12, 11};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  LCD.begin(16, 2);
void lock()
void unlock()
if(customKey_one = keypad.getKey())
      if(customKey_one != '#')
        if (customKey_one != '*')
         //Get password
                      Data_one[data_count_one] = customKey_one;
                      LCD.setCursor(data_count_one,0);
                      LCD.print(Data_one[data_count_one]);
                      data_count_one++;
        }else
        //Unlock process
         if (data_count_one == 4)
                    LCD.clear();
                    LCD.setCursor(0, 0);
                    LCD.print("unlock bike");
                    LCD.clear();
                    LCD.print(Data_one);
                    // Transfer code from Data_one to UnLockCode
                    data_count_one==0; //reset counter
                  }else
                        LCD.clear();
                        LCD.print("num only");
                        LCD.clear();
        }else
      //Lock process
      { if (data_count_one == 4)
                  //Lock
                    LCD.clear();
                    LCD.print("lock bike");
                    LCD.clear();
                    // Transfer code from Data_one to LockCode
                    // Send signal to hardware
                  }else
                        LCD.clear();
                        LCD.print("Number only");
                        LCD.clear();
}//if customeKey_one
}//end loop
Plz spply mor detls. What are you trying to do? In what way is the code supplied not doing what you expect?
No.
If you are going to misspell "length", you have to do it consistently.
MorganS:
thank u
ok thank u
