pls. help: multiple alarm sched on different pins
hi, pls. help me modify the code in this link:http://forum.arduino.cc/index.php?topic=42151.0
i already had an arduino board. i need to program pin1 to HIGH at 7am for 1 minute, pin2 to HIGH at 10am for 1 minute, pin3 to HIGH at 12pm for 1 minute, and so on and so forth on daily basis.
i dont want to use RTC module to avoid complexity. Time setting calibration or update must only be done via code update and upload via IDE.
Thanks in advance.
(deleted)
i see. ok i need to buy RTC module. i have the following reference code. can anybody pls. modify it based on my needs? lcd display not required as time setting can be done via direct code modification.
By the way, where can I get the libraries mentioned below?
/* ----- C Program for Arduino based Alarm Clock ---- */
#include <Wire.h>
#include<EEPROM.h>
#include <RTClib.h>
#include <LiquidCrystal.h> >>>>>>>>>>>NO NEEd LCD
LiquidCrystal lcd(3, 2, 4, 5, 6, 7);
RTC_DS1307 RTC;
int temp,inc,hours1,minut,add=11;
int next=10;
int INC=11;
int set_mad=12;
#define buzzer 13
int HOUR,MINUT,SECOND;
Wire.begin();
RTC.begin();
lcd.begin(16,2);
pinMode(INC, INPUT);
pinMode(next, INPUT);
pinMode(set_mad, INPUT);
pinMode(buzzer, OUTPUT);
digitalWrite(next, HIGH);
digitalWrite(set_mad, HIGH);
digitalWrite(INC, HIGH);
lcd.setCursor(0,0);
lcd.print(“Real Time Clock”);
lcd.setCursor(0,1);
lcd.print("Circuit Digest ");
delay(2000);
if(!RTC.isrunning())
RTC.adjust(DateTime(DATE,TIME));
int temp=0,val=1,temp4;
DateTime now = RTC.now();
if(digitalRead(set_mad) == 0) //set Alarm time
lcd.setCursor(0,0);
lcd.print(" Set Alarm “);
delay(2000);
defualt();
time();
lcd.clear();
lcd.setCursor(0,0);
lcd.print(” Alarm time “);
lcd.setCursor(0,1);
lcd.print(” has been set “);
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“Time:”);
lcd.setCursor(6,0);
lcd.print(HOUR=now.hour(),DEC);
lcd.print(”:");
lcd.print(MINUT=now.minute(),DEC);
lcd.print(":");
lcd.print(SECOND=now.second(),DEC);
lcd.setCursor(0,1);
lcd.print(“Date: “);
lcd.print(now.day(),DEC);
lcd.print(”/”);
lcd.print(now.month(),DEC);
lcd.print("/");
lcd.print(now.year(),DEC);
match();
delay(200);
void defualt()
lcd.setCursor(0,1);
lcd.print(HOUR);
lcd.print(":");
lcd.print(MINUT);
lcd.print(":");
lcd.print(SECOND);
/Function to set alarm time and feed time into Internal eeprom/
void time()
int temp=1,minuts=0,hours=0,seconds=0;
while(temp==1)
if(digitalRead(INC)==0)
HOUR++;
if(HOUR==24)
HOUR=0;
while(digitalRead(INC)==0);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“Set Alarm Time “);
//lcd.print(x);
lcd.setCursor(0,1);
lcd.print(HOUR);
lcd.print(”:”);
lcd.print(MINUT);
lcd.print(":");
lcd.print(SECOND);
delay(100);
if(digitalRead(next)==0)
hours1=HOUR;
EEPROM.write(add++,hours1);
temp=2;
while(digitalRead(next)==0);
while(temp==2)
MINUT++;
if(MINUT==60)
{MINUT=0;}
// lcd.clear();
lcd.setCursor(0,1);
lcd.print(HOUR);
lcd.print(":");
lcd.print(MINUT);
lcd.print(":");
lcd.print(SECOND);
delay(100);
minut=MINUT;
EEPROM.write(add++, minut);
temp=0;
/* Function to chack medication time */
void match()
int tem[17];
for(int i=11;i<17;i++)
tem*=EEPROM.read(i);*
  • if(HOUR == tem[11] && MINUT == tem[12])*
  • beep();*
  • beep();*
  • beep();*
  • beep();*
  • lcd.clear();*
  • lcd.print(“Wake Up…”);*
  • lcd.setCursor(0,1);*
  • beep();*
  • beep();*
  • beep();*
  • beep();*
    /* function to buzzer indication */
    void beep()
  • digitalWrite(buzzer,HIGH);*
  • delay(500);*
  • digitalWrite(buzzer, LOW);*
  • delay(500);*
Please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum Your code is too long for me to study quickly without copying to a text editor.
…R
