pls post me with ir sensor speed measurement code
am using an ir sensor with a +pin , a -pin and a output pin i tried many codes to get the output with lcd ......pls help me with a code
That's not the way it works. You post your non-working code, and we help you understand why it doesn't work, and how to fix it.
volatile byte rpmcount = 0;
unsigned long rpm = 0;
unsigned long timeold = 0;
int interrupt = 0;
sen_analog=A0;
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);
{lcd.begin(16, 2);
attachInterrupt(interrupt,rpmtrigger,FALLING);
if (rpmcount >= 20)
rpm=((15000)/(millis()-timeold))*rpmcount;
timeold = millis();
int time = (millis()/1000);
int timedec = (millis()% 1000);
rpmcount = 0;
lcd.print(“RPM = “);
lcd.print(rpm);
lcd.print(” Time = “);
lcd.print(time);
lcd.print(”.”);
lcd.print(timedec);
lcd.println();
void rpmtrigger()
rpmcount++;
And we also get very, very upset with people who post the same question in different parts of the forum.
This is called cross-posting and we hate it because IT WASTES TIME.
Cross-post deleted.
Edit: . . . and we also hate it when people don't read the simple posting guidelines displayed at the top of every section of the forum.
It hasn't started well, has it?
i have posted my code sir
tanveer: i have posted my code sir
You have posted it without using code tags. Did you read the posting guidelines at the top of the forum?
If you are expecting rpm values greater than 32, 767, you are dreaming.
Magic numbers don’t cut it.
    timeold = millis();
    rpmcount = 0;
You’ve got a shitload of slow stuff going on before you reset rpmcount. Hope that +/- 50% is good enough.
So, what is the problem with the code?
