Pluggin in Bluetooth shield breaks simple serial comm program.
I am having a really hard time getting my blue-tooth shield to work, so I started to write a program that sent messages via the USB/serial connection from my Uno to my PC. Here's the code:
int inByte = 0;         // incoming serial byte
  // start serial port at 9600 bps:
  establishContact();  // send a byte to establish contact until receiver responds
  // if we get a valid byte, read analog ins:
  if (Serial.available() > 0) {
    // get incoming byte:
    inByte = Serial.read();
    Serial.write(inByte);
    Serial.print('B');   // send a capital A
void establishContact() {
  while (Serial.available() <= 0) {
    Serial.print('A');   // send a capital A
    delay(300);
The thing is, this works fine if it is JUST the arduino--but if I plug in the BT shield (and change NOTHING in the code, just reupload) the thing breaks!!! Instead of responding to commands, it just keeps sending 'A' ad infinitum.
This doesn't make any sense to me but I am hoping you guys know what is going on. Why would plugging in a shield have any impact at all on a program that doesn't use the shield in the first place???
Not knowing your bluetooth-shield I just can guess: If the shield connects to the very same Rx/Tx-pins (0/1) as the USB does, you cannot use both at the same time.
