Plugin is running, but not detected by create on Crouton linux
Plugin is running, but not detected.
Installed Crouton linux besides my chromeos on my chromebook because the plugin doenst work on chromebooks :frowning:
It was running, but after a reboot it doesnt work anymore
Debug shows:
time=“2017-03-24T16:16:50+01:00” level=info msg="[{/dev/ttyUSB0 0x7523 0x1a86 false}]"
time=“2017-03-24T16:16:50+01:00” level=info msg=""
time=“2017-03-24T16:16:52+01:00” level=info msg="[{/dev/ttyUSB0 0x7523 0x1a86 false}]"
time=“2017-03-24T16:16:52+01:00” level=info msg=""
time=“2017-03-24T16:16:52+01:00” level=info msg="[]"
But arduino editor states:
No Plugin Connection. Uploading is disabled until you reconnect.
any ideas anyone?
The CHROME OS is not yet supported for the plugin.
You can however log into CREATE and create a sketch and save it with ANDROID based devices to upload later on a host that runs and of the following three.
Windows Linux Mac OS
What you are doing is running an instance of linux as a second layer to the chrome os and I doubt that it will work as intended. You could try using SUDO to drop in the plugin but there is zero guarantee it will work.
Take a look at some of the linux based posts in here to see if they offer any clues.
Windows here so only giving you what I have seen on my travels through this section.
Hi @dysan, we are sorry but we never tested Crouton linux so we don't know how to help, let us know if you can make it work!
Hi, I'm having the same issue described by the OP.
I'm running Ubuntu
The plugin looks normal, even reinstalled and the web procedure said I was good to go, but the yellow message saying there is no Plugin still appears.
Using latest firefox on Ubuntu 16.4 LTS
Please advice what could I do?
