Looking at signal 1.
30 hz is 33.333 ms.
You want it on for 10 ms, and off for 23 ms ?
Is this program intended to run for more than 4 weeks without resetting the processor? Since it seems to need multi tasking to do signal 1 and signal 2, there are a couple ways to do that, depending on how long the program will be running.
signal 1: 30 Hz= 1000/30 = 33 Ms for one period so the signal I want = 23 mS on (5 V), 10 mS off (0 V)
signal 2: 600 Hz= 1000/600=1,67 mS for one period, so the signal i want= 1,5 mS on , 0,1 mS off
this signals will only be used on the workbench for a short moment (to see iff the MPGUINO is working correctly, when everything is working correctly, i will mount it on the motorcycle..
accuracy is not so important, because it is only for test purpose
Since signal 2 is faster, you need to use micros() rather than millis().
That would make
signal 1: ON 23000 micros and OFF 10000 micros
signal 2: ON 1500 micros and off 100 micros
Check the reference for micros(), there can be some differences depending on which board you are using.
Great, you have it solved.
Would you mind sharing your results/script with us. Someone else may need a similar setup, and would benefit from your solution. Thanks
// global defines & parameters
// #define HZ_33_H 20303 // 20303 micro seconden voor de 33 Hz Hoog duur #define HZ_33_L 10000 // 10000 micro seconden voor de 33 Hz Laag duur #define HZ_670_H 493 // 493 micro seconden voor de 670 hz Hoog duur #define HZ_670_L 1000 // 1000 micro seconden voor de 670 hz Laag duur
enum {
laag, // simpele verwijzing naar array indices
hoog
enum {
Hz_33, // verwijst naar de 33 Hz waarden
Hz_670 // verwijst naar de 670 Hz waarden
// global variables
uint32_t timer1; // timer voor de 33 Hz
uint32_t timer2; // timer voor de 670 Hz
uint32_t timerWaarden[2][2]; // bevat de tijdsduur voor de puls timers
uint8_t Hz_33_Level; // verwijst naar hoog of laag duur 33 Hz puls
uint8_t Hz_670_Level; // verwijst naar hoog of laag duur 670 Hz Puls
main loop of program and runs endlessly
uint32_t nu = micros();
// test de 33 Hz timer
if ((nu - timer1) > timerWaarden[Hz_33][Hz_33_Level]) {
// we moeten de polariteit wisselen
Hz_33_Level = !Hz_33_Level;
// schrijf alvast de output
digitalWrite(PULSE_33, Hz_33_Level);
// en start de timer voor de volgende switch
timer1 = nu + timerWaarden[Hz_33][Hz_33_Level];
// test de 670 Hz timer
if ((nu - timer2) > timerWaarden[Hz_670][Hz_670_Level]) {
Hz_670_Level = !Hz_670_Level;
digitalWrite(PULSE_670, Hz_670_Level);
timer1 = nu + timerWaarden[Hz_670][Hz_670_Level];
wim2584:
Accuracy is absolutely important; 33Ms is well over a year (very nearly 382 days).
Please remember to use code tags when posting code
